On start pump runs for 2 secs then nothing for a min then try's again. spin end light lit
  • 31 Answers
Sounds like the timing control connections are worn or dirty. i would unplug it or flip the breaker, and look there first. check for continuity on the various contact points with a multimeter. Red wire/probe of the meter goes on the black or "line in" " "120V". this tells you if it is making good contact as the timer control spins around.
Posted on Oct 07, 2010
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Hard starting when cold. 30 sec to min crank. Runs good after start.
Hi Thomas:
Sounds like it's not getting fuel right away.
I'd be checking the choke, and also perhaps try priming by pushing gas pedal all the way down twice, spin over 2 or 3 seconds, then pump gas pedal twice again, then try to start.
None of this is valid if it is a diesel.
Sep 17, 2015 | Cars & Trucks
I have a 2001 Chevy Malibu that wont start. All of the lights on the dash come on and when they settle.. only the battery and the check engine light are on. It has a full tank of gas and full oil and...
When you turn the key to the start position does the starter spin the engine ? The engine cranks no start ! Or nothing happens when you the key to start position ? no crank no start ? Is the anti-theft light lit on the instrument cluster (SECURITY) ? If the starter spins the engine does spin slow or normally ? Is there spark , fuel pressure ? Testing these thing's would be the place to start if the engine spins ! Videos on youtube showing how !
Apr 14, 2017 | 2001 Chevrolet Malibu
Power led light on when pressing power it tuns on and goes of right away? power still lit..
I have the same problem, did you figure out what the problem is and solution by any chance? i purchased it recently, it started doing this the night after i left it on for the night. next day everytime i turn on, it turns off in 2 sec. after a month i tried a shot, it started and stayed up for 1 min may be... then same thing again 2 sec. i guess i have to wait for a year to turn it on .
garden led light
May 29, 2012 | Office Equipment & Supplies
2001 grand prix will not start. New battery
Have you tried checking your ground wire? 1.Try taking each end apart giving it a good sanding to clean up to bare metal and try again. 2. The ground wire itself or other wires running to the coil, might need to be replaced. Try taking off individual wires and testing them with a 12 volt light bulb to see if current is still following through them. Good Luck.
Jul 12, 2010 | 2001 Pontiac Grand Prix
Pump runs for about 15 secs then cuts off.
try testing the starting capacitor by first disconnecting the power, opening the cover on the end of the motor, and test the resistance of the capacitor
Jan 24, 2010 | AO Smith SQ1152 Pool Pump Motor
MB 190E will start and stall within 2 seconds
cold start relay either the fuse in the relay, or the relay itself.
Jul 21, 2009 | 1987 Mercedes-Benz Mercedes Benz 190 Class
Riello oil burner RDB with red plastic cover at the front wont ignite. I've tried bleeding the valve. The motor seems to make an electrical humming noise for about 12 secs, then the system attempts to...
The motor should spin when the boiler is switched on. One end of the motor spins the fan the other end works the pump. The control box then starts the transformer that starts a spark. The control box then opens up the oil. The boiler should then light if any of the above or the boiler does not light, the boiler will go to lockout.
From what you say the motor is not spinning, thus it could be the motor or more like the pump.
YOU SHOULD NOT PLAY WITHE THE PUMP
If the wrong setting is made it could 1 burn out the back of your boiler 2 go to soot and the boilers in an hour would be filled up and become a fire risk. 3 not start at all if the setting is too low it is a fine line to get it to work and needs the right tools.
regards
oil eng.
Oct 26, 2008 | Heating & Cooling
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
