Desktop video My computer hasnt been turning on sometime..it turn on sometime and it doesnt..like the monitor doesnt receive anything but the cpu is on.. and sometime it freezes when the computer turns on when sometime when that happen, some of the fan doesn't turns on!! i dont know whats wrong with it
  • Tranceyboy May 29, 2008
    do you think i neeed a better power supply? and what do you mean short some where? like there's a loose wires?
  • 55 Answers
Most probably its a issue with
1) SMPS / Power supply
2) Motherbaord - Short some where (Test it for earthing)
Posted on May 29, 2008
  • Sarvesh Sonawane May 30, 2008
    hi
    i think we need to DIGNOSE you each device one by one for fault.
    So lets get your hand dirty ..::.. :-)
    1) SMPS is not delivering proper power supply ->
    Through SMPS you computer converts various power supplies into computer
    for example HDD requires 5 Vold supply mother board required 12 V .
    So when smps in not delivering proper power to various hardwares so may be your computer can show the above symptoms.
    Check your SMPS
    Requirement :- Multimeter, Small metal wire/ Pin
    Steps:-
    1) Disconnected all outgoing connections from SMPS (for example power to motherboard, HDD, CD Rom etc)
    2) Now lovate the socket of SMPS which is used to connect to Motherboard (The Biggest one)
    3) Now inseart small wire / pin in to Green + Black wire (Short Green+Black)
    4) Now give power input to SMPS , which will make SMPS start working (Obeserve the FAN on backside , it starts rotating)
    5) Now take multimeter and check the voltage comming from each wire by putting Multimeters Black / Comm wire into BLACK Pin on SMPS`s Motherboard Connector.
    Please refer following diagram for Referrence of Output voltages from various cords
    (Otherwise you can refer the stikker sticked on SMPS box )
    So if all voltages are comming with proper desired ratings then we can conclude that SMPS is working fine
    2) Motherboard Short -->
    Here just cross check whether any Capacitor on mother board is swollended or not.
    Please refer following images
    Obeserv the swollen caps.
    if it is also not the case with your motherboard then there may not be problem with your motherboard (cheers ..::.. :-))
    These capacitors are getting swollen due to faulty power supply, faulti memmory modules etc.
    Please reply the resolution
I've seen many others post this exact issue but there hasnt been any real solution that I can find. I have a DELL XPS Gen4 Pentium 4 3.6 GHz desktop. When I start the computer, the CPU fans go into...
I am having the exact same problem, but it only happens intermiddently. If I unplug the computer and then plug it back in it will ussually work for a while before it happens again.
Feb 11, 2011 | Dell Dimension XPS Gen 4 PC Desktop
Its in hibernate mode doesnt wnt to get out of it
Turn your computer off and turn it back on. See if the video comes back. If it doesn't then try another known working monitor on the computer. If you get video with the 2nd monitor then that means the original monitor is bad. If you still don't get video with the 2nd monitor then that means there is an issue with the CPU because you have no video output.
Nov 03, 2010 | Samsung Computers & Internet
My compaq computer wont turn on for more than a second. It boots and the cpu fan starts but than the monitor doesnt show anything even though its on, the fan turns off and the computer stops booting. I...
1) Is this a laptop or a desktop?
2) What OS are you running?
3) When was the last time that it booted successfully? Did anything change then? Did you upgrade the OS? Did you upgrade the software (firmware) on the processor (Intel or AMD)?
4) Do you see anything on the screen? Compaq logo? Boot options?
Feb 01, 2018 | HP Compaq Presario SR1500NX (PX786AA) PC...
I just got a used syncmaster 203b monitor. I hooked it up and all I get is a black screen. I downloaded Driver whiz and hooked it up again. Still a black screen. Still get a black screen the blue light is...
Make sure that your computer unit is working. Sometimes we suspect that it is a monitor problem but usually, it is a frozen CPU set.
When you turn on the monitor, it should light the blue led and after a while, when it does not receive signal from the CPU, it will turn orange. If that is the case, the monitor is functioning well.
So what could be the problem?
Make sure that you hooked the monitor to the right VGA port. If you have an internal VGA port (built in with the motherboard) and you also have an external Video Card, you should hook it to the external VGA port and not the internal one since it is overridden by default.
Do you hear the "short beep" sound when you boot your PC? That signals a good video system. If you don't hear that beep sound (provided your PC's speakers are okay), you should open your CPU case and try to remove your memory modules (RAM). Clean the pins with an eraser and put it on.
Now, your computer should work fine and so with your monitor.
Aug 14, 2010 | Samsung SyncMaster 203B LCD Monitor
When turning on my pc the led comes on but nothing happens
Sounds like your video card isn't working anymore. Most likely your video is "on board"; meaning that it's part of the motherboard configuration. Sometimes this can be resolved by putting a new video card in one of the PCI slots on the motherboard and setting your BIOS to use that instead of the integrated\on-board video. I've had times when this doesn't work either because the entire chipset is burned-out and malfunctioning. I would suggest that you don't spend alot of time & money on repairing or attempting to repair this computer. It's pretty dated compared to the technology that is available now.
Apr 21, 2010 | Compaq Presario 5000 PC Desktop
No display on monitor
if you have a video card in it try connecting it to the motherboards vga/dvi and see if you get any video. if not it could be ram/cpu or mobo if its not beeping my bet is on the mobo
Feb 14, 2010 | Gateway Essential 400 PC Desktop
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
. Led will light up but cpu does not power up.
Does the CPU fan rotate? And no monitor activity? Sometimes the hard disc has some kind of activity. This could be attributed to loose/failed in memory in the syste. You can try to reseat or clean the memory edge connector with clean eraser. But power down first yur unit and unplugged to wall socket no power connection shall be connected.
Sometimes it doesn't make any beep code. If beep is generated this could be video problem. But check first the Ram and video, before getting to anything.
Post an update.
Jun 03, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
My IBM Monitor doesnt turn on but the CPU is on.
You may have changed setting by mistake so while powering cpu first time press f8 f8 frequently and you will go to safe mode and see the picture
Oct 29, 2008 | IBM ThinkVision L170 17" LCD Monitor
Computer gets power, but doesn't display anything
remove your video card and plug it again.. if it doesnt work..
try plugging ur video card to *********** board built in video card and then ur on-board video card to you monitor..
this is what the nvidia guys mentioned on their video while announcing the release of the 9 series
May 07, 2008 | Toshiba Satellite P25-S607 Notebook
Computers & Internet Logo
2,744 people viewed this question
David Payne
David Payne
