Question about Homelite Mighty Lite Lawn Trimmer
Starts and shuts off as if starving for gas. - Homelite Mighty Lite Lawn Trimmer
  • 1,040 Answers
Here is a Link to a couple of my Tips
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
This should solve your problem.
Good Luck!
Posted on Oct 07, 2010
1995 chevy truck 305 engine .shuts off after a few seconds starts back up again put in gear shuts off.
At this age the pump would be a good bet. How many miles/years are on the current pump ?
Jul 30, 2015 | 1995 Chevrolet K1500
My 1987 Mercedes Benz E300 runs fine but once I put gas in it it starts sputtering and shuts off then will start hours later. Help please!
try changing the fuel filter which is next to the pump its unlikley its the pump more likley muck in the fuel line which is blocking filter starving the engine making it cut out
Apr 15, 2015 | Mercedes-Benz E-Class Cars & Trucks
I have a honda 50 2007 and i took apart the carb cleaned it thoroughly, replace the on off valve and sdpark plug. it ran great for a couple of days. now it starts first kick runs for a minute or so then...
sticky float needle- run some seafoam through a tank of gas- also check for vacuum leaks as the petcock on bikes with a petcock are usually vacuum operated off engine vacuum.. if disconnected or leaky- that will starve the engine once the fuel in the float bowl is used up.
Jul 11, 2014 | 2007 Honda Shadow Aero
2012 john deere x320 mower tractor
You may have gotten dirt from the bottom of the tank up into the fuel line. Try changing the fuel filter. If that is plugged it will be starved for gas.
Jul 05, 2013 | Garden
86 f250 runs fine for a while then starves for gas
Starves for gas??? Starts to stall? Sputters idles funny?? Gas and O2 issues ackd alike. Gas starvation is usually a filter problem or god fobid the Fuel pump. Do you smell gas? See a leak??? Need more info here
May 19, 2012 | 1986 Ford F 250
Car shuts off as if starved of fuel remove fuel line and prime car starts
There's a fuel pump relay that turns on the fuel pump, as you turn on the ignition before the engine starts, to prime and pressurize the injectors. I'd check the relay it may not be operating.
Nov 07, 2010 | 1990 Nissan Axxess
2003 Jeep Liberty check engine and security Light
CK the mass air flow sensor. First sensor on duct coming out of air filter.
Jun 13, 2009 | 2005 Jeep Wrangler
Car runs great then stops like its starving for gas, let it sit for couple hours then it starts up again
Check the ignition module, and fuel pressure when the trouble is present. Those are the two things on Neons that cause this problem
May 27, 2009 | 1998 Dodge Neon
Car Starts but wont go.
It could be a couple things. There may be a vaccuum leak in the fuel system such as a bad EGR or PCV valve or the throttle position sensor. I'm leaning towards the throttle position sensor needing replaced. The throttle position sensor reads how far you're pressing on the gas peddle and then feeds that to the computer telling it how much gas to feed to the engine. If that sensor isnt working right then your car will get enough gas to start and idle but will starve for gas as soon as you try drive and will then stall.
May 12, 2009 | 1993 Dodge Caravan
Homelite Mighty Lite Lawn Trimmer  Logo
52 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
