Question about Candy Washing Machines
CANDY gof 462 - 80 Washer goes through cycle so far then cold fill button begins to flash and washer stops. It wont go into spin. Then it rurns itself off.
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
  • 183 Answers
SOURCE: washer
The fault could be caused by several things, 1. it has a blocked air trap, 2.the lid switch is faulty. 3. The motor to gear box coupling has sheared off or the motor is faulty, there is nothing else that can cause this fault. Regards Engineer
Posted on Jul 29, 2007
  • 94 Answers
SOURCE: My washer washes, but doesnt rinse...
I sounds like it needs a new timer.
Posted on Oct 08, 2007
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
SOURCE: samsung vrt washer will begin cycle but get so far
Had this same issue and decided to check it out myself since I didn't have the warranty on my machine.
Before the machine can start the spin cycle, it needs to drain the water that touches the drum. If it cannot do this, you will get the "nd" error code which means "no drain". This can mean your drain pump is screwed or that something is jammed somewhere in the drainage patheway.
First drain the water using the little hose in the front of the washer. This can be done faster by putting the machine in test mode and test the drain pump. it'll push the water out much faster. Once you've drained the water, flip that bad boy on its side and start taking apart the hoses starting with the ones leaving the drum first. That is where I found my obstruction, a quarter :/ If there is nothing there, keep going till you hit the drain pump. You'll have to take it out to really get in there and unclog it. DO NOT HIRE SOMEONE TO DO THIS! I had never done anything like this before and was able to easily figure it out. GOOD LUCK!
Posted on Feb 19, 2011
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Stops during rinse cycle
    Dear customer,
                  We recommend the following when a washer's cycles dont advance..
    1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
    2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
    3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
    For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
    Plz rate this solution.. thank you..
    Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Soon as i set cycle and swich on door light flashes open
    hi,
    Thanks for your question.
    Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
    Whirlpool AWO3761 stuck mid-cycle
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
    Washing Machines Logo
    374 people viewed this question
    Top Candy Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Kolbrun...
    Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
