Question about Toshiba Televison & Video
I am setting up a Model DVR670KU recorder. Chanel setup and link to tv OK. I manually set the clock. It does not show on the front panel display window. The "L1" input mode is displayed. I have checked the clock setting setup procedure and the clock is correct in this process each time. It does not display however. Thank you.
SOURCE: How do I record a TV Program.
Video & Left,Right audio go out of Comcast cable box to L1 input on DVD recorder,Video & Left,Right audio go out of DVD recorder to a line input of your TV.  Record L1 input on DVD recorder.
Posted on Feb 04, 2009
SOURCE: won't allow manual clock set - tv guide not loading
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ( |<< ) and "Time Slip" and "Open/Close" for 5 seconds.
will self check, say test L1, power off, on again.. go thru setup. no data was lost.
Posted on Apr 06, 2009
nandosnut
  • 112 Answers
SOURCE: setting the clock on the dvd recorder
Follow this sequence on the remote control:
Press FUNCTIONS/To Others/Setup/Others/Clock to access the clock setting mode. There, you will have the choice of Auto or Manual. Take your pick and away you go!
Posted on Apr 20, 2009
SOURCE: DMR-EZ48V Clock no longer displayed on the front panel
Turn off power saving.
Posted on May 27, 2009
  • 11800 Answers
SOURCE: Toshiba Model D-R5SU DVD Recorder Default
The timer and the schedule memory (and its activation) are kept active by the power source of the unit. In your case the source is no longer delivering the stable voltage the memory circuit and the processor needs to keep the data stored and processed - a sign that the source has aged and its components, mainly the filtering capacitors, will have to be replaced by a repair shop. You must take the unit to one, there is nothing else you can do to it.
Posted on Jul 03, 2011
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
How do you reset clock on your DVD Recorder DMR-ES15. Can't find booklet that came with recorder.
You can either copy and paste the following link into your browser, for quick-view, and/or save the .pdf document (instructions for Panasonic DMR-ES15 DVD recorder):
http://videolinq.tafe.net/attached_docs/pdf/equipment/Panasonic_DMR-ES15_User_Manual.pdf
(verified and complete to give you a basic operation manual for FREE download)
or you can try to set the clock manually, do this:
press [FUNCTIONS] on the remote while unit is on, to bring up the setup menu, scroll to 'OTHERS' look for 'CLOCK' or 'CLOCK SET' option, highlight it, click it, set the clock. Press [ENTER/OK] to access the date hour minute, etc., then press the relevant remote arrow buttons to select correct time/date, then press [ENTER/OK] to store the current setting. Then press [RETURN] to exit the setup. Clock is now set (this model does not offer automatic clock adjustment for daylight saving).
If the above suggestion does not work, download the pdf and save it for accurate reference. Either may help you.
May 01, 2011 | Panasonic DMRES15 DVD Recorder
How to set a clock on a hd dual tuner dvbr dch3416
The clock should set automatically, synchronized with your cable provider's time. You can't change it, as far as I know. OR does it display the channel number and you want it to display the time? If so, go to your onscreen menu (home), choose setup, choose cable box setup, front LED display: current channel ----> current time.
Mar 14, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
Won't allow manual clock set - tv guide not loading
Apr 04, 2009 | Panasonic DMR-E85H DVD Recorder
Can't change the clock time
Best Solution posted Nov 6, 2008, by Guest -- worked for me. Wondering what the DST is? -- Daylight Savings Time. There will be a button at the bottom right in the date OFF. Apparently the TV Guide programing does not work that well, especially with the new Digital boxes now need to receive over the air TV and the TV Guide programing never worked with Satellite TV. Wil this feature ever be up dated? I doubt it. It would be nice to have the digital box and your dvr cycled together.
Nov 03, 2008 | Panasonic DMR-E85H DVD Recorder
Panasonic dmr-eh50 Clock setting greyed out - unable to reset clock after clocks went back.
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Oct 26, 2008 | Televison & Video
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
DMT-E95 can not set time
Two options.
Select Auto - You will need to plug in a coaxial standard TV antenna for the auto clock function to receive an atomic clock pulse. After a few seconds (sometimes minutes) it will display the correct time. Once the time is displayed you can disconnect the TV antenna if you want.
Or, select Manual then OK or Enter - Then use your arrow keys on the remote to set the time.
I would always recommend auto mode. If you don't have a TV antenna you can poke a miniature screwdriver in the coax socket just to get a clock signal.
Instruction manuals are available online, if you Google you'll find one.
Regards
Helen
Feb 24, 2008 | Panasonic DMR-E95HS DVD Recorder
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
278 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
