Question about Dell U0636 Mouse
I bought a new Vostro laptop not long ago and since I first bought it, the mouse has been very difficult to use. For instance, when I try to move a window, instead of moving the window, the window maximizes. I have tried adjusting the settings in the control panel, but nothing seems to turn off this weird behavior. I am tempted to buy a new mouse, but I am not sure a new mouse would change this weird behavior. I think it is a bug in Windows 7. Any suggestions?
    Problem Solver:
  • 25 Answers
Please update the driver software to see if helps.
http://www.newlaptopkeyboard.com
Posted on Oct 07, 2010
How to perform scroll function in laptop without mouse in Dell vostro
Your touch pad should do the trick.
They are called "Gestures". They are set to active by default. If it's not. Go to "Control panel > click "mouse" and find "touch pad". There you will find "Gestures". Activate it.
1. Put two fingers on the touch pad and try to move both fingers up or down. Learn how to scroll up and down.
2. Move those fingers side ways. This should do the "Horizontal" scroll.
There are others, like:
Put one finger stationary and rotate the other. This rotates the orientation of the object.
Try it and good luck.
May 23, 2014 | Dell Vostro 1510 Laptop
My touchpad is not working at all
i think it is driver failure so you can reinistall the driver.to inistall use usb mouse or bluetooth mouse? i think it help you
May 09, 2014 | Dell Vostro 1015 Laptop
Mouse Pointer of Dell vostro 1014 laptop touchpad is working in reverse i.e. while moving finger on touchpad towards right the pointer move in left direction & vice versa
Hi, the laptop touch pads have an icon near the clock or u can find it on the control panel, there is a check mark that said" mouse reverse"or "mouse look up" or something like that,uncheck it to work properly and download the latest driver,
kind regards
Apr 17, 2013 | Dell Vostro 1014 Laptop Computer
My Dell Vostro 1014 laptop's touch pad does not work!! The buttons work fine but I'm having problems with the pad. The drivers are up to date and the application used to control the touchpad c
If you have a external mouse, or you can borrow, go into device manager to see if the pad is enabled, if okay! try a system restore bringing the computer back in time before this happened, if still no luck the sensor pad maybe defective, the last option a complete recovery of the operational system to factory setting, this will prove if the sensor pad is defective, or wire ribbon might have come loose from the motherboard.
Apr 01, 2012 | Dell Vostro 1014 Laptop Computer
I bought a dell vostro 1015 a week ago with windows xp as os. the moment i'm trying to connect my 2-year-old ipod nano through the usb port, the laptop is going hung. itunes shows nothing and the ipod...
Try downloading the latest iPod patch from the manufacturer's website (apple.com). Then restart your computer and reconnect your iPod to your laptop.
May 26, 2010 | Dell Vostro 1015 Laptop
A few months ago my Dell Vostro 1500 laptop started saying that my battery could not be detected. I bought this laptop new in October 2007 and did not extend my warranty. I bought a new battery and...
Normally the message means that the battery is bad and needs to be replaced. There is a chance the new battery you got was defective and went bad before its time.
The motherboard can be the problem, although it is not common for this to be the case.
I would try one more battery before thinking about a new motherboard, a new battery is under a $100 where a new mobo is several hundred, and usually this is a sign of a bad battery. If you disconnect the ac adapter and it stays on then it is using the battery, although it is reporting that it cannot see a charge. I would guess the battery malfunctioned and is not being able to be read by the laptop.
Sep 12, 2009 | Dell Vostro 1500 Notebook
Mouse moves to different lines then where i'm typing
hi pls check the onther mouse , after you are idetifiy , you mouse is not working ,than idetifiy your mose remove the yahoo messenger and retart the pc and downlod the new setup file for yahoo msg and install after ..............yahoo msg is working ................100%
Mar 30, 2009 | Dell Vostro 1400 Intel Celeron M M540...
OUT OF CONTROL
OK. So lets start from the top. This problem could be related to software or hardware. The easiest way to decide this is by plugging the mouse into another pc if possible. Although the first thing I would try is replacing the batteries with it being battery operated. Also ensure that the optical eye on the bottom of the mouse is unobstructed. Some optical mice also react odd when used on different surfaces, it is always best to use a mouse pad. Lastly if none of this changes the operation, you may want to reinstall the provided software.
http://www.targus.com/UK/product_Details.asp?SKU=AMW1601EU
Mar 12, 2009 | Computers & Internet
Mouse and Keyboard problems
sounds like the electrical connector to these devices is somehow partially disconnected. Must open machine and look at these connectors to verify insertion. Good luck on opening machine...it is quite difficult and try to have a camera handy to snap photos of difficult areas for later reference.
Nov 16, 2007 | Panasonic CF18DJAMXKM Notebook
Dell U0636 Mouse Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
