Question about Saeco Coffee Makers & Espresso Machines
I need a manual for a 2 group Rio espresso machine, or how to change the pour time for shots.
  • 40 Answers
SOURCE: Saeco Vienna Digital Expresso Maker - brew group will not line up to fit back into espresso machine
Could be a number of reasons. If you "hear" the brew group moving in one direction, stop and then move again, then the microswitches are o.k. If the sound of the movement is low and/or slow ( slower that normal), the CPU/power board may be bad and needs to be replace. If the movement is as before (same sound and movement) but not lining up, perhaps the brew drive motor is bad.
To remedy this situation, an authorized SAECO Service Center would have to open your machine and replace damaged components. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
  • 29 Answers
SOURCE: Need a repair manual for Saeco Italia Espresso machine
http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
at the bottom of this page u can download the manual
Posted on Feb 27, 2009
  • 5 Answers
SOURCE: need to program stafco markus 2 group espresso machine
Normal you hold in the continuous flow button till all lights flash or stay on.
then you press the first button to program, once the right amount of coffee has come out press that button again.
Continue this with all buttons.
Please sign up to servicing program, we teach you how to service and maintain your machine. This will save you $$$ hundreds in service agent fees. We stock all parts.
Email me at sales@willisjococoffee.com.au
Posted on May 11, 2009
  • 3 Answers
SOURCE: i need owner manual for brugnetti mc1 espresso machine
I have all the repair books for the MC-1 let me know if I can help.
Posted on May 20, 2009
EsWorld
  • 1618 Answers
SOURCE: Grimac ZOLA II - NO HOT WATER !!!
The problem is either the switch that controls the solenoid for the hot water valve, or the solenoid itself. Place finger on the solenoid coil and press switch if the solenoid is working you will feel the nucleus when it engages. If both switch and solenoid are working then the pipe connected to the solenoid from the boiler is clogged.
Posted on May 22, 2009
Program error
Yes the flowmeter needs to be checked the impella or head needs to be replaced.
Feb 10, 2014 | Nuova Simonelli Premier Maxi Espresso...
Espresso shots pour very slow for both the single and double shots.
Did you try adjusting the group head screw? And/or cleaning and checking the valve in the group head? Good visuals and instructions here: https://myprojectsandmods.wordpress.com/2014/10/27/delonghi-ec702-espresso-machine-no-water-flow-fix/
Feb 03, 2014 | DeLonghi EC702
Water coming slow
filter plugged or pressure weak.
Dec 17, 2013 | Wega Coffee Makers & Espresso Machines
How do I increase grouphead pressure on la marzocco linea 2 group?
To increase dispense pressure you turn the adjustment screw at the pump. When pulling a shot (use espresso) on one group the bottom needle of the gauge should read 9bars while pulling the shot.
Dec 16, 2010 | La Marzocco Linea Series Group 3 Espresso...
Water is leaking around the edges of the basket and into the shots. Is this an o-ring gasket or a group gasket issue?
Group gasket issue, depending on the age of the machine the gasket might be dirty, use a Q-tip or your group brush to clean, if machine has over 2 years use then replace group gasket.
Sep 02, 2010 | Gaggia Carezza Espresso Machine
My e61 group head on my Diadema UNICO Splendor exhaust port probs
There might be one of 2 things going on,
1- the exhaust tube is blocked.
2- one of the three gaskets in the group is on backwards.
Jul 24, 2009 | Coffee Makers & Espresso Machines
Just started blowing the breaker. Late in the day so I turned it off.
4 grp Rio, probably running on a 50Amp breaker. Check the electrical connections on the pump(if you model has an internal pump it would be above the switch there is a 3 connector bridge.
Check the switch, there may be loose connection, also check the plug and receptacle.
Check the element connections that would be the most likely suspect for a breaker blow.
Check to make sure that nothing else is on the same breaker as the machine.
May 25, 2009 | Saeco Rio Vania Group 4 Espresso Machine
Buzzing Espresso Machine
that noice is from your solenoid valve during brewing coffe.
  1. as first you should clean the group with blind filter and special detergent for washing coffe from group. if you didnt do this long time you should repeat the cleaning 3 - 5 times same day.
  2. if you follow the 1st instruction but you have the problem again you should change your solenoid valve.
Mar 18, 2008 | La Marzocco Linea Series Group 3 Espresso...
Not making espreso all the time
Being that you just started using it I would not be concerned. You did the correct thing by cleaning the brew group. Check on your screen under total coffees. We usually recommend you change the brew group every 10,000 cups.
Make sure you descale the machine and you can try using the cafiza tablets to clean your brew groups internal passages.
Brew Group: http://cerinicoffee.com/Saeco_brew_group_Magic_royal_916006715.asp
Cleaning instructions: http://cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Nov 19, 2007 | Saeco Royal Exclusive 30153 Espresso...
Coffee Makers & Espresso Machines Logo
182 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
