Question about Western Digital Caviar WD2500BB 250 GB Hard Drive
Installing a secondary HDD
I installed a WD 2500js as a secondary drive in my HP Compact 1750NX with XP SP2.... I had purchased this drive for my son but he did not need it and it set here for months so I decided to intall it in my PC..... I can see the WD drive in CMOS and see it in the device manager (all is working properly) but can not see it in "my computer" or access it. I would think in may need to be formatted but if I can not see it I can not format the drive
    Genius:
  • 1,066 Answers
It needs to be activated . control panel/administrative tools/ computer management/disk management
Posted on May 29, 2008
Am trying to install vista on my windows xp-sp2 but it gives "spinstall is not a valid win32 application......how to install then???
Are you doing a Dual-Boot? With a Separate Partition on the Primary HDD? I'm a bit confused? Are you doing a install on the Primary HDD and installing over the Win XP? Did you format the HDD? Or on a second HDD?
Mar 20, 2013 | Microsoft Windows Vista Ultimate Edition
Installing XP SP2 on Compaq Presario R4000, after
Run a HDD Test
Restart Computer -> Immediately keep tapping F10 Key which is on 1st row of Keyboard
Go to diagnostics with your arrow keys
Go to Primary HDD Test -> Press Enter ->
See the Test result
If Fail then Contact HP for Replacement of HDD or Service
Jun 01, 2010 | HP Compaq Presario R4000 Notebook
SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Jul 29, 2009 | Computers & Internet
SOYO KT600 Dragon Plus mobo not recognize WD Caviar SATA 1TB HDD
Yuck! Soyo filed for bankruptcy in May and their website is gone!
You need to enable the SATA in the rom bios AND install the drivers for it; but, I hope you have the manual and the CD.
Jul 05, 2009 | Soyo Computers & Internet
Installing XP home edition with SP2: Won't recognize hard drive
Hell, Sorry to hear your having problems your analysis sounds correct but lets make sure it's not something else first. Can you give me more details on the drive Brand, IDE/SCSI, model number. Do you have access to a computer with a CD burner?
Mar 16, 2009 | Microsoft Windows XP Home Edition
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Mar 23, 2008 | Intel Motherboard
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Western Digital Caviar WD2500BB 250 GB Hard Drive Logo
149 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
