I have a panasonic cu-80c52hp air con unit with a fault code of IF42 the system will start up and start cooling then after a bit switches off the compressor and will not switch back on till you turn the system off then back on again, what is the code IF42
  • 86 Answers
SOURCE: Panasonic split system air con cs/cu-e24gkr
check the indoor unit sirkit board,there is problem.
Posted on Mar 15, 2008
koolbreezes
  • 540 Answers
SOURCE: KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
Posted on Aug 23, 2008
SOURCE: Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Posted on Dec 08, 2008
SOURCE: My Blueway air con is not cooling , fan works but is not cooling
More than likely the capacitor is bad internally
Posted on Jan 21, 2009
  • 306 Answers
SOURCE: Not Cooling At all.
Sounds like you lost the refrigerant charge. No freon in other words. If you are sure the compressor is on then that is the only thing it could be.
Posted on Mar 02, 2009
I have a panasonic inverter air con. Model CU-E18LKR. it's not cooling properly. Seems to be blowing cold air out on th outside rather than inside.need instructions on troubleshooting
This is a reverse cycle (heating and cooling) model. It sounds like you have it in heating mode. Check the Panasonic website for an owners manual.
Jan 30, 2017 | Panasonic Heating & Cooling
Panasonic ac unit keeps coming up with a fault.... the error code is F90 air con is 5kw
dont no the code but if you call pana and tell them the code they should no what it is. not always usefull as they can give a general response but worth a try. then post the answer.
Jan 20, 2013 | Panasonic Heating & Cooling
Hi, I have a Panasonic cu-80c52hp and it recently started to leak water from the ceiling unit. I took the cover off and notice that there is a round rubber approximately 4-5cm wide which is leaking...
Any hose that is of the right size will work fine.. take a piece to the local hardware store and they should be able to help you .. OR you can take and blow ******* the hose that you have and perhaps get it cleared. You don't need a special hose just one that is clear. Hope this helps let me know Jon
Aug 03, 2011 | Heating & Cooling
Remote doesn't work on air con
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
Sep 19, 2009 | Heating & Cooling
KELVINATOR KSR20C
Aug 02, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Feb 14, 2008 | Heating & Cooling
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
