Formated hard drive from win98 format.com using format C;/s. HD 32 bit formatted. Want Hd formatted 16 bit. Compaq desktop built 1987. F2 does not work. F1 does not work Which key gets to HD configuration?
    Problem Solver:
  • 15 Answers
Are you referring to the file system?
Do you have a copy of DOS?
I think you want to create a partition using the FAT16 File System.
If you have it use FDISK (old DOS app), once it loads it asks you if you want to enable large disk support - just say no and then delete all current partitions on your HD and recreate a new one.
Warning: Make sure you have the correct drive selected as this will delete everything on the drive.
FAT16 Partitions can only go up to 2GB in size, so you cant make any bigger ones with it.
Partition Magic and programs like that can also be used to manage disk partitions. Let me know if you need anything else
Posted on Oct 07, 2010
  • MrCloister Oct 07, 2010
    Before you get into that, I think you might be able to do it with the Format command
    Format C: /FS:FAT
    This will format the C: drive in FAT 16
When I plug my smartdisk firelite USBFLB40C into the usb port it says it needs to be formated. What is the problem?
If it is new and has not come pre formatted then you need to format it to match the system as it still could be in RAW state, but I would expect usb devices to be preformatted. (not always the case though)
A bit of history:-
FAT32 recognised by all windows systems ( but does not support files more than 4GB)
NTFS recognised by systems other than FAT32 (and supports files above 4GB)
FAT 32 was the native format for WIN98 but unfortunately when XP came along many companies continued to format in FAT32 for XP machines especially for the home user. (and XP would run quite happily with the format)
NTFS was and is the more stable of the two.
Jul 26, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
I have an old laptop that partition and hd have been reformatted. I've tried using boot disk but keep getting the message that says, ''save to disk partition not found. So, can't get win98se to load as...
Haven't used win98 for a while so bear with me and this uses DOS COMMANDS too.
If useing restore cd/floppy you have to use a utility from compaq that creates two partitions on hard-drive.
They may have a restore floppy if you need it too.
One for "recovery files" and one for "OS Boot"
AHH, the memories, I still have my 95/98/ME Laptops up and running for older stuff. HP n CQ too.
Restore CD should do it all though.
If no restore CD - have Win98 CD?
if Harddrive partitioned and formated - Just do 1
1. boot from Win98 CD.
Partition n Format
2. Choose boot to DOS (puts u in virtual drive A)
AT PROMPT
3. Type drive letter of CD ( C: D: or E: )
4. Type CD Win98
5. Type Fdisk ( to partion drive)
reboot n do 1 + 2
6. Type format C: ( I do this to ckeck drive for errors)
OR
JUST Boot from CD and follow install instructions.
1 to 6 for if you have problem with Win98 CD setting up Harddrive.
Apr 04, 2010 | Compaq Presario 2140US Notebook
Formatting a buffalo hd-ce500u2
hi there, if you would like to format it, all you have to do is plug it into the computer, go to my computer, and right click on the drive. Then, click format. After that, click on the format button and let it be for about a hour or two. After it is done, the drive will have been formated.
Jan 30, 2010 | Buffalo Technology DriveStation HD-HC500U2...
How to add a new harddisk to a Gateway Peninum 3 550MHz machine and install win98?
Do you want to replaced the main HD or add a new one? If you want to replace the main one, buy a Hard drive under 160 gigs. I cant remember but 98 can not deal with a bigger one, you will have to cut it up or Partition it. Partition it down to 20 gig each. Do you have your Org. win 98 install disk? Get a setup program with the HD you buy. That program should let you Partition it and also format it to use with 98 or fat32. Once installed in the computer set the HD to master with switches located on the drive (small jumpers) As it boots up look for press DEL to enter setup. Get into the BIOS program and ck to see it it will locate your new hard drive you might have to set heads and scetors so make a note of the stamped on the drive. Once the BIOS has found the drive it is a matter of format w/ copy the command comm program from win98 you will have to have a good win 98 set up disk. Once you have formated the drive with fat32 and copied commamd.com you will need to install CD/Rom drivers you might have to find a good old win98 starup disk to boot up the cd. you might find a good old floppy with a cd intall on it at a local computer shop. if using an old win98 startup disk you can then put in the cd and at the Prompt type in cd win98 then type in  setup and that should be a good start.
Oct 23, 2009 | Gateway computers9: Pentium 3 Computer...
I formated my hard drive due to a rookit virus. I then installed the windows angelical but when the windows is loading the pc shuts off and provides a error.
boot the pc up into something like Kill Disc then format the HD then try and install windows again if this fails try booting into HD Regenerater repair the HD then once this has completed fully try and reinstal windows this should solve the problem.
Jul 23, 2008 | Computers & Internet
I ve just bought a lacie desktop hard disk 500gb and its not doing anything
New hard drives are "Raw" and have to be formated for any Operating system to recognize it. If the Hard drive is installed I would suggest, if you have a Win98 cd, boot from that, select with cd rom support, at the prompt type in fdisk, Fdisk will display all fixed disks present, select your new HD and configure it, with large disk support, etc.
If you don't have a win98cd download GParted live cd and burn on cd. and boot with that it will display all hard drives and you can select your new HD and format it to fat 32 or ntfs or linux ext partitions/swap files.
Mar 31, 2008 | Computers & Internet
Unable to boot, I can't installed WIN98
NTLDR is NT Loader which indicates that the hard disk originally contains an NT OS such as Windows XP. The laptop not reading the installer is possibly a CD ROM or CD disc problem. Most (but not all) NT OS would be using an NTFS type of HD format. Windows 98SE would only read and install on a FAT(32).
What perhaps you can do is to remove the HD from the laptop and using an external 2.5 interface to USB connect it to a 2nd PC and re-partition that HD as well as format it to FAT32. You can also make that HD bootable (do a Google) and copy the entire CD installer of Windows 98SE to a folder inside that HD.
Once back to the laptop, it should boot to a C: prompt, go to the folder where the Win98SE installation/setup files are located and run setup.exe.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 06, 2008 | Compaq Armada E500 Notebook
Samsung SpinPoint SV1203N 120 GB FHD
Try increasing the actual partition to the capacity numbers in the windows xp formatting , and also format the hard drive using NTFS .
Dec 08, 2007 | Samsung SpinPoint V80 SV1203N 120 GB...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
