Question about Air Tools & Compressors
Im looking for a wiring diagram for a SULLAIR LS12/50 so i can wire a remote stop start to a relay
Static relay continue click
Posted on Feb 24, 2013
Rrbb74@yahoo.com
i have electrical wiring diagram sullair LS12-50 ,thanks.
Posted on Feb 27, 2011
2002 Jeep Liberty starter "clacks" about every 2-3 minutes even when the motor is shut off and key is out of the ignition.
Does your vehicle have a remote start? Its possible that the remote start is malfunctioning. I had a vehicle with similar issues, and I didn't even know it had a remote start. (The previous owner had one, but had never told me about it, or given me the remote for it.) If you have a remote start, it should be located under the dash, next to the steering column, or firewall, or under the drivers seat. Disconnect the wiring harness from the remote start if you have one.
If you are sure you have no remote start, or if the problem continues after disconnecting it, then follow these steps.
1. Locate the small diameter wire going to the starter solenoid. The starter solenoid will be on the starter itself. This wire will be much smaller than the large wire that comes directly from the battery. This wire is is likely fastened with a round crimp connector and a philips head screw. Or it may be a clip on plug.DISCONNECT THIS WIRE. If the "clacking problem" continues with the key off, when the wire is disconnected, then you can be sure that the starter has a problem. If the problem stops (Of course it won't start either) Then proceed to step 2.
2. At this point you may want to take it to a professional who has the wiring diagrams to properly troubleshoot. But if you are up to it, Hook the disconnected wire back up to the starter, and locate the wiring harness coming from the key switch and disconnect it. If the "clacking" stops, replace the key switch. If it doesn't, then you have a short, or wire harness problem. At this point you probably need a wiring diagram and professional troubleshooting experience to proceed further.
Dec 09, 2014 | 2002 Jeep Liberty
What wires are hooked up to left & right posts going to & from starter rely on 1987 f250 4wd straight six
You don't need a diagram. The batt Pos goes to one side and that is also the power side for various other tasks. The second heavy stud goes to the starter. You just have the smaller supply cables on the wrong stud.
Aug 10, 2014 | 1985 Ford LTD Starter Relay
Looking for a wire diagram for the brake lights or the location of a breake switch
Purchase a Haynes manual at Autozone or most auto supply stores that covers your make and model year. There are several wiring diagrams in the back of the book. It costs $24.95. Im sure you'll find the diagram you are looking for.
May 06, 2014 | Cars & Trucks
Installing remote start looking for wiring diagram
Here is a site that claims to have free wiring diagrams for every vehicle:
http://www.bbbind.com/index.html
When there, look under technical information.
Oct 01, 2013 | 1999 Dodge Dakota
LOOKING FOR WIRING DIAGRAM FOR A SULLAIR 750DP ROTARY SCREW COMPRESSOR. MANUFACTURED IN 1982 FOR U.S.N.
I would contact Sullair factory, they have a great support group that I have contacted not as a Sullair distributor and the still provided me with the information I requested. have the model and serial number when you call them. there number is 1-888-775-1604
Feb 03, 2010 | Air Tools & Compressors
My power locks dont work in side my van
check the wiring, connections, curciut braker, fuse link for the door opener on the side is broken, compair the wiring is the same setup on the working side and the non-working side.
something is different on one of the malfunctioning side, remote setting device has the correct wiring setup and the wiring diagram setting are defferent something is making the system to operate wrong or right. just be careful and teaduse, check out the remote switch and remote relay, fuse for relay, relay, find schamatics, look at the wiring remote wiring diagrams, and compair power connection for remote verses the non remote, see if any wires loose, dangling aound, loose, good luck
rod
Feb 16, 2009 | 1999 Chevrolet Venture
Info on Aftermarket Generations Alarm AGA1201
The first link takes you to a good cheap place to buy this particular Aftermarket Remote System
The second two links offer diagramming and installation information. Hope this helps.
http://cgi.ebay.com/NEW-AGA1201-FM-Car-Alarm-Remote-Start-Keyless-Entry_W0QQitemZ230313882162QQcmdZViewItemQQptZCar_Alarms_Security?_trksid=p3286.m20.l1116
icon_bins.gif www.the12volt.com/ · Cached · Save Free vehicle wiring diagrams and technical information for car stereo, car alarm, electronics installers. Ohm's law, resistors, passive crossovers, subwoofer boxes, ... Free Vehicle Wiring, Relay Diagrams, ... ... icon_bins.gif www.vastbeyond.com/440.htm
Find Free Automotive Wiring Diagrams! ... Your Simple Source for Free Automotive Wiring Diagrams ... Free Automotive Wiring Diagrams.
Jan 07, 2009 | Chevrolet Cavalier Cars & Trucks
Air Tools & Compressors Logo
407 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
