Question about SanDisk 2GB microSD Memory Card
It dose not work it says memory card not formatted when you want to format it does not format at all
    Brigadier General:
  • 10,406 Answers
Recycle it, and spend $10 to buy a replacement 2GB card.
Much less money than paying a technician a minimum of $25 to _try_ to trouble-shoot it.
Posted on Oct 07, 2010
New memory card dose not work. Keeps saying formatting. Its called SDHC memory card multi use.
Your problem is it's an SD"High Capacity" (SDHC). This type of card came out after camera was designed, and although it looks the same as a standard SD card, its not. Sorry, but there's no way to make that type of card work with your camera. But just go on Amazon, You can purchase a standard 2GB that will work with your camera for about $6 to $7 (total with shipping).
For others reading this with similar problems, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 25, 2011 | Kodak EasyShare Z760 Digital Camera
Memory dose not format
Please try the card on another PC if the card is not detected in your PC and if the card cannot be formated then check and see if the tiny LOCK on the side of the card- to protect erase- is put to ON. If so reset and if this wont work still the card is faulty.
May 19, 2011 | SanDisk 2GB microSD Memory Card
Why dose my camera say SD protecetd?
Your SD card is locked meaning is write protected. To unlock it you need to slide the small plastic toggle out of the 'lock' position. See image below
Dec 28, 2010 | Fuji FinePix S7000 Digital Camera
When I try to view the photos taken I get a blue screen on most of them with 'file error' shown on screen. How do I overcome this?
Format memory card, format option is available in camera menu and if this dose not solve problem, replace memory card.
Jan 20, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Memory card auto removing
Hello There
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Mar 10, 2009 | Nokia N73 Music Edition Smartphone
Why dose my phone & pc want to format my sd card
you must've done somethig wrong it cant happen by itself, once corrupted there's nothing you can do
but try formatting it with vista and that should work
Mar 04, 2009 | SanDisk 2GB microSD Memory Card
MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
Nov 06, 2008 | Nokia 6600
How to format nokia 3110c
Hi i m Almadani, i have Nokia 3110c,
in 3 or 4 days when i change my sim or insert a memory card,
so when i on my mobile after few seconds the cell switch off then on every time i on my cell then switched off after few seconds,
when i on with out memory card then the cell work normaly,
so waht i do for that?
can i formate it?
if i want to formate, then how i to formate?
reply me.
thankyou
Sep 05, 2008 | Nokia 3110 Cellular Phone
Nokia 6630.Changing Memory problem and phone memory low errors
try again format ur phone,but b4 that,put out ur memory card.after format ur phone,format ur memory card on pc by using card reader.after both format complete,put ur memory in phone,format ur memory card again in phone.ok.try this 1st.send feedback to me.
Jun 21, 2008 | Nokia 6630 Cellular Phone
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
SanDisk 2GB microSD Memory Card Logo
23 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
