Question about Frigidaire Dryers
I press the start button and hear an electric humming noise and the drum does not turn.
  • 550 Answers
Unscrew the rear panel of the dryer,
You will most likeley find the rubber drive belt broken and wrapped around the drum or motor.
if so
Take your make and model details to your local parts dealer and pick up a new belt, for a few $
like a fan belt it installs snaked around the drum, motor, and backwards around a tensioner
Posted on May 29, 2008
Drum not turning
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 06, 2012 | Kenmore Dryers
I have DBSR4EB3WW model number. Last night I was drying clothes, tryed to turn dryer back on , turned the button to right to start clothes and all it would do is make a humming noise. ...
Hello Deborah, it could be a number of things, First the belt, usually if you hear a humming and the drum isn't turning, Its a broken or slipped belt, the hum you hear is the motor turning, But with no belt the drum can't turn other things that can go wrong and cause this are the safety switch located by the dryer door has failed, or a thermostat located in the rear of the machine is bad or stuck if you feel you can check these things , thats cool, just let me know you want to give it a try ,
Jun 16, 2011 | GE DBSR453EBWW Electric Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Mar 20, 2010 | Whirlpool LER4634J Electric Dryer
Humming noise when i press the start putton
When I push the start button it would hum if I hold the button to long and then it would cut off.
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
May 23, 2007 | LG DLE2512W Electric Dryer
Dryers Logo
66 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
