Question about Philips Televison & Video
Remote Rc 2585/01 Philips Direct tv need a manual or the codes and how to input them. This is a remote that does not have a code search button just mode and the usal sat,vcr, and tv. thanks all.
  • Ot Tap
    Ot Tap Feb 23, 2013
    Got it all do not work the same .
I HAVERC2583913/01B REMOTE ---I DON'T KNOW ABOUT HIS CODE
Posted on Feb 23, 2013
2 Suggested Answers
Puppet03
  • 172 Answers
SOURCE: need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Posted on Oct 24, 2009
Testimonial: "Thanks!!! I received a response within a matter of minutes and resolved the problem. "
I'M LOOKING FOR THE 4 DIGIT CODES FOR A PIXEL TV TO SET UP A UNIVERSAL REMOTE CONTROL
How can I manually setup my universal remote control?
www.p4c.philips.com/cgi-bin/cpindex.pl?...
Philips LCD TV 32PFL7684H 81 cm (32") Full HD 1080p digital TV with Pixel Precise HD. 32PFL7684H/12. 32PFL7684H/12. Search for information about this product. Product ... Enter the 4-digit RC code of the device you wish to setup.
26PF7521D/10 26" LCD digital widescreen flat TV Pixel ...
Search for information about this product ... In digital mode, press the 'DIGITAL TV/MENU' button on the remote control to display the setup menu. Press the cursor up/down button to ACCESS RESTRICTIONS and press the cursor ... Note: If you have forgotten your personal 4-digit pin code, enter the universal code (0711).
Searching for Your Code - Universal Electronics Remote ...
www.urcsupport.com/html.php?page_id=314
Dec 22, 2015 | Universal Remote Control Televison & Video
I need the universal codes for my verizon fios remote, otherwise another recommendation of a universal remote that will operate my tv.
Setting up the Philips RC 144 remote if the remote codes are invalid or unknown If you do not know the remote codes for a device, or if you've tried all the listed remote codes for your device and none of them work, you can search for the correct remote code by following the steps below.
Note: These steps only apply to the Philips RC 144 Remote Control. If this is not the make and model of your remote, go to the supported remote control models page and find the instructions for your specific remote control.
Searching for a Device Code
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons.
    The mode buttons blink twice.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of the Play button.
  5. Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
  6. When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
  7. Note:
    There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
    If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Feb 28, 2011 | Apex Digital LD4088 LCD TV
Need instructions to set code for tv
  • 1 Download or view the user's manual from the Magnavox website (see Resources). You will need the list of codes included in the manual. The website will direct you to the closest remote control manual available similar to the REM 350 Universal Remote. This manual is compatible with the REM 350 Universal Remote.
  • 2
    Press and hold the "Code Search" button until the red indicator light stays on. Release the "Code Search" button.
  • 3
    Press and release the "Mode" button for the product you wish to program (TV, VCR, DVD or satellite). The red indicator light will blink, then stay lit.
  • 4
    Enter the four-digit code from the code tables listed in the user's manual. You can also search for the code online at the Philips Universal Code Finder page (see Resources). You might have to try several or all codes listed in the manual until you find the correct one. After a valid code entry, the red indicator will turn off. With an invalid code, the red indicator flashes.
  • 5
    Press the "Channel Up" button with your device on (TV, DVD, VCR, or satellite). If the device responds, you have completed the programming. Once are certain you have found the valid code, make a note of it somewhere so you will not have to search for the code again.
  • Jan 14, 2011 | Philips Magnavox REM-350 Remote Control
    I have a remote contorl universal philips .i'm tring to makc my citezen tv work lost instruction manual serial numb 50804225
    Direct Philips Magnavox Universal Remote Code Entry PM335
    1. Press and hold the Code Search button until the red
    indicator stays on. Release the Code Search button.
    2. Press and release the desired mode button (TV,
    DVD, etc.).
    The red indicator blinks, then stays lit.
    3. Enter the 3 digit code from the code tables. Note:
    after a valid code entry, the red indicator turns off.
    For an invalid code, the red indicator flashes.
    4. With your device on, press CHANNEL Up. If the
    device responds, no further programming is
    required. Note: If some buttons do not operate your
    equipment, try one of the other codes for your
    brand.
    CITIZEN .... 002 112 402 407 502 512 701 805 906 319
    Please rate this solution. Thanks.
    Aug 24, 2009 | Philips SRT9320/10 Prestigo 20-in-1...
    Programmin my remote
    Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
    I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
    Jul 15, 2009 | Olevia LT32HVM 32 in. LCD Television
    Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
    Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
    Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
    Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
    Press the "TV" button on the remote to program the Philips remote to your television set
    Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
    Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
    Code for universal remote rm-810
    There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
    1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
    2. Point the RC right to the "Device" .
    3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
    4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
    5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
    You can try the RC now. It should work. My one is working.
    Aug 19, 2008 | Philips Magnavox Learning Universal Remote
    I am lookin for a code for a universal philips remote to use on a zenith tv dont know if this is waht yhou do but it came up int hte search for what i asked for
      indicator stays on.
    2. Release the Code Search button.
      Press and release the desired mode button likeTV,
      DVD)
      The red indicator will blink, then stays constantly lit.
      Enter the 3 digit code as below.
    3. Please note: The red indicator will turn off if code entry is valid but will flash for invalid codes.
    4. With the device on, press CHANNEL Up. No further programming is required should there be a response from device. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
    TV
    ZENITH ............. 241 142 345
    Aug 15, 2008 | Televison & Video
    Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
    SETTING CODES
    HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
    PRESS THE DEVICE BUTTON (ie TV)
    CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
    PRESS THE MUTE BUTTON TO SET THE CODE
    Feb 03, 2008 | Philips Magnavox Learning Universal Remote
    Televison & Video Logo
    1,800 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
