Question about Homelite Mighty Lite Lawn Trimmer
Need carbuerator kit for 4hcps.0254ah trimmer
  • 1,041 Answers
This Link:
www.searspartsdirect.com/partsdirect/brands-products/Homelite-Parts/Grass-trimmer-weed-wacker-Parts
is as far as I can get you without the Model # of your trimmer. But this should help you find what you are looking for
Good Luck!
Jim
Posted on Oct 07, 2010
I have Ryobi weedeater that has a new Carbuerator,getting gas to the cyl.an has good fire to the plug an will not start need help bad
Make sure u r not getting to much fuel. With switch off pull string twice then turn switch with throttle cable helded wide open try to start.good luck.new dose not mean adjusted good luck
May 31, 2014 | Ryobi Garden
Need to either buy a carbuerator or a carbuerator kit for my 1992 honda accord, do u know where i can source such.?
car parts stores are located every other corner in every city. you go by a dozen or so every day.
stop at a car parts store if you want to buy a car part.
Aug 19, 2011 | 1992 Honda Accord
My mechanic explains to me I need a replacement carbuerator for my 85 Toyota pickup. He exp;ained to me that 85 was the year in which upon importation a "simple" carbuerator became very complex...
if you changed the carburator then what would he do with the computer and emissions stuff he left unconected. just take the car somewhere else and have it rebuilt. or if your good at following instructions you can buy a rebuild kit for it from any auto parts store and do it yourself. just rem it goes bk together the sameway it came apart.
Jan 31, 2011 | 1985 Toyota Pickup
Im looking for a service manual or instructions on carbuerator adjustments for a poulan pro mod # 331 weed trimmer
visit www.zama.com --excellent site shows applications & theory of carburetors
Sep 23, 2009 | Garden
Dear friends, I'm looking for carbuerator
I believe that number is a Craftsman number. You need to know what kind of carb you have, either float-type or diaphragm-type. The float type has these pre-set: the main jet is 1.5 turns open. The idle jet has 1 turn open. The diaphragm type both start with 1 turn open. When you have it running you can go ahead and set it. Good luck...Lee
Sep 21, 2009 | Garden
I have a TB425cs that won't accelerate. It will
try adjusting the mixture screws out a bit if any otherwise it will need a diaphram kit
Jul 16, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
New kit installed. Will start then dies and will not restart. How to adjust carbuerator on my tb70ss?
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. You should be able to see daylight through it. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 13, 2009 | Troy Bilt Tb70ss Gas Trimmer
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
After rebuild only runs on half choke.Adjusting screw doesn't help
The rebuild you did is correct, but did you clean the small ports in the carb.? I use a Den Tek Brush (used for cleaning teeth). They work great for this job. You may also want to check the small screen in the carb. The smallest of particles can cause this problem.
Jim
May 25, 2009 | Poulan Garden
Homelite Mighty Lite Lawn Trimmer  Logo
397 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
