Question about FireLite (USBFLB80) Hard Drive
I have a smart disk JH5504 that has damaged pins. Can I have repaired or hook up another way?
    Brigadier General:
  • 10,406 Answers
If it is the pins on the exterior of the enclosure that are damaged, you can buy a new "empty" enclosure, and "transplant" your disk-drive from the old enclosure to the new enclosure.
Costs about $30 for the new enclosure.
Posted on Oct 07, 2010
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
S.M.A.R.T Status BAD
The SMART function on your computer monitors your SATA hard drive to let you know if it is at risk of failing. This software detects bad sectors on your hard drive and repairs them when you initiate a repair. You can use the Disk Utility on your Apple computer to repair the SMART errors on your hard drive. The Disk Utility has an easy to use interface so even a novice can perform this task.
Insert your OSX install disc into the computer's optical drive. Start the computer while holding down the "C" key. Choose your language from the menu that appears. Click the "Installer" tab and then click "Open Disk Utility" form the menu, Click the "Disk Utitlity" icon from the menu and then click the "First Aid" tab at the top of the menu. Click the "Repair Disk" button and wait for the repair to complete. Restart your computer. Windows PC Click the "Start" button and then click on the "Computer" option. Right-click on your SATA hard drive and then click the "Properties" button. Click on the "Tools" tab and then click the "Check Now" button. Click on the box next to "Automatically fix file system errors" and then box next to "Scan for and attempt recovery of bad sectors. It might take some time depending on the of the disk be patient. Have no input while the chkdsk utility is in progress any input might further damage your hard drive. Click the "Start" button. Restart your computer after the scan and repair have finished to clear your SMART error.
Feb 02, 2013 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
Smart disk error 301
Anytime the Error 301 messages appear on your computer, it is due to corrupt or damaged system files.
If you do not fix this error immediately, it can lead to additional system issues, blue screens and hardware problems.
Frozen programs, installer errors, random shutdowns, system freezing and sluggish computer performance are common symptoms of the Error 301.
Fortunately, you can fix the Error 301 with features native to your computer.
Click "Start" and then "Computer." Right-click "C" and select "Properties."
Select the "Tools" tab and click "Check now." Select "Continue" if the User Account Control prompt displays.
Select the "Automatically Fix File System Errors" option and click "Start." Agree to reschedule the check for the next system restart.
Reboot your system.
Allow the check disk to detect and repair all Error 301 issues.
you should have no input while chkdsk utility is in progress any input might further damage your computer it might take some depending on the size of the disk be patient.
Hope this helps
Oct 28, 2012 | HP 500 GB SATA Hard Drive
When pc boots My wdc hard disk shows sec master hard disk S.M.A.R.T status bad backup and replace
your hard disk getting damage so take back up fast and replace hard disk with new hard disk smart test when hard disk want when hard disk surface going some hardware problem
May 22, 2012 | Western Digital Computers & Internet
I have a disk in my apple computer that will not eject when I press the eject arrow
If you look carefully you will see a pin hole on your disk drive built in to your apple computer.
The disk inside the disk drive might be stuck or the there can be some damage in the disk driver. Either ways you can insert a sharp pointed object like a needle or a pin in the pin hole. This will eject the drive.
If the disk drive does not eject, to avoid any further possible damage the laptop has to opened and the disk drive has to be removed and inspected. If the above solution solved your problem, You disk drive may start to function properly otherwise if there is no hole (since many disk drivers have no holes) or the insertion and poking of needle does not work the only recommended option is that you have to take it Repair shop or give it to a tech.
Good Luck!
Jan 06, 2011 | Computers & Internet
Smart failure hard disk 4 :wd1600bevt-222ct0-(si)
The error S.M.A.R.T. refers to Hard Drive hard drive that has detected damage to the disk and failure of the drive is imminent.
If the computer is booting to Windows after the SMART error, then back up all data on the disk immediately. The hard drive will need to be replaced to resolve this issue.
Also, I suggest that you start the Computer to BIOS and check whether the Hard Drive is detected in BIOS.
If the Hard Drive is detected in BIOS, then try to perform reinstalling Windows supplied in your computer once before getting the hard drive replaced.
Dec 20, 2010 | Toshiba Satellite A215-S5822 Laptop
Replace rear rotors on a 1994 Volvo 850?
raise support vechicle safely.if you see no guide pins.mark the position of the wheel on the hub.then remove the wheel.remove caliper and pads.do not disconnect brake line to caliper.use a piece of wire to hang caliper out the way dont let caliper hang by brake hose.it could damage it.to remove brake disk to have to locate the mounting stud or pin to remove disk.when you locate the stud or pin that hold the disk in place.remove brake disk.make sure parking brake is off or it will be hard to remove brake rotor.when installing new brake rotor make sure the holes is the same as the old one or it will not fit.now if you want pictures you have to buy a haynes repair manual.
Jun 14, 2009 | 1994 Volvo 850
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Invalid media
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 22, 2007 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
FireLite (USBFLB80) Hard Drive Logo
95 people viewed this question
Top FireLite Computers & Internet Experts
Paul Bade
tdk1988
John Anderson
John Anderson
Are you a FireLite Computer and Internet Expert? Answer questions, earn points and help others
