Question about Ricoh Aficio 2022 All-In-One Laser Printer
Errorcode: SC:544 Fuser is ok, procedur clear? Please help.
3 Suggested Answers
SOURCE: REPLACED TRANSFER BELT; CLEARED TRANSFER
problem solved by replacing NVRAM on BCU.
thank you for your reply
Posted on Dec 05, 2009
micromatikal
  • 2777 Answers
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
Posted on Oct 25, 2010
Help need for getting rid of SC 544-00 on a Ricoh SP C830DN machine.
SC 544 is a fuser overheat error. This could be caused by power outage or fluctuation in the power.
go to service mode. Hold down both "home" and "simple screen" for about 5 sec. and then press "user tools"
once in service mode go to SP5810 reset fuser error.
and reboot the machine.
Feb 19, 2017 | Ricoh Aficio SP C830DN - Printer - color -...
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Fault Code 010-319
Dear
Its the fuser related problem in secind level service. As the fuser assy.has replaced with a new one so but the problem remains. This has to be checked and clear all errorcodes stored in NVRAM during service peroide of the machine. As its very crucial operation on its software you may need the help of trained engineer to do so.
After clearing the errorcode the old fuser assy.may work.
Thanks.
Jan 29, 2015 | Office Equipment & Supplies
My aficio richo 2016 black and white copier is showing code error sc 544. pls how do i fix this problem.
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
May 11, 2011 | Ricoh Aficio 2016 Black and White Copier
Error sc:544
Hi
SC544 error means Fuser Overheat Error 1 (Hardware). This has happened due to Fuser Low Temperature which occurs due to Abnormal Hot Roller Fusing Lamp Lower Limit Temperature Detected. Try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If it doesn
Oct 09, 2010 | Gestetner DSm615 Digital Imaging System
When copier is putting on , it displays " error code SC:544"
that is a fuser overheat code. You can try pressing clear all, then enter 107 and hold the stop button until you see the SP mode come on the machine, then as it is in that mode, shut the machine off and back on.
If that doesnt work. I would suggest replacing the fuser unit.
You would need thermistors, rolls, overheat thermostadts.
Individually they would cost more than replacing the fuser.
Aug 12, 2010 | Ricoh Aficio 2015 Copier
Sc 544 lanier ld 122
CALL FOR SERVICE YOU WILL NEED NEW THERMISTORS NEW THERMOSTATS AND MOST LIKELY HOT ROLLER,CLEANING ROLLER AND HR BEARINGS COST OF TIME AND PARTS WILL BE 400 TO 500
May 17, 2010 | Office Equipment & Supplies
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Gestetner DSM616
Turn the machine on, and press clear modes, 1, 0 ,7, and press and hold the clear stop key. It will beep, and a menu will appear. Select copy SP (1), and then select data log (#7) scroll until you get to 7807 (sc/jam counter reset). select it, and press execute. exit all the way out, and recycle the power. If it comes to ready, it should be ok. If it happens again after that, there is a fuser problem of some sort.
Mar 05, 2008 | Gestetner DSm616 Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2022 All-In-One Laser Printer Logo
102 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
