Which access panel, on bottom, to remove to replace bios battery on Toshiba M35-S359 laptop
micromend
  • 748 Answers
SOURCE: Toshiba Satellite M35 and BIOS/CPU Replacement
No the BIOS is not a replaceable chip. Yes the BIOS can be reflashed once the computer is working. And, definitely Yes. An overheated CPU will definitely cause a shutdown.
Posted on Mar 24, 2009
  • 163 Answers
SOURCE: Toshiba Satellite M35-S359. No audio. Sound
Modem chipset on systemboard is bad most likely.
Posted on Jan 04, 2010
igor106
  • 277 Answers
SOURCE: Toshiba M35 S359
The LED blinking is a BIOS POST error code that points to a fault in the power regulating circuitry on the motherboard. This is a well known problem with Toshiba M Series laptops.
You will need to replace the motherboard, or go for this solution here:
http://imateski.blogspot.com/2008/08/toshiba-satellite-m35x-motherboard.html
Posted on Mar 30, 2010
walesarumi
  • 6993 Answers
SOURCE: Toshiba M35 S359 Laptop screen brightness
you can try windows up date, or check the control panel, locate display and check the Brightness settings.
It is also possible that part of your screen bulb is dead, that's why one part is dimmer.
But there is no drivers that will make your screen bright.
Take care.
Posted on May 29, 2010
dbestever
  • 73 Answers
SOURCE: oprating system not found on my toshiba satelitte
try restoring your factory image...
try pressing the following when your Toshiba splash screen shows on your laptop:
F11
F10
ALT-F11
ALT-F10
one of those should bring you to your factory image for your laptop... however, if the hard drive is damaged, you may need to take it in for repairs.
If you need further help, reach me via phone at https://www.6ya.com/expert/jim_8aa10a90cbbc76ff
Posted on Mar 10, 2011
My Toshiba M35 passsword Bios not work. I can't do anything.Please help me to reset! Thank ALl
Hello, try disconnecting and then reconnecting the battery. If that doesnt work try running a start up program from a cd, something like Symantec as these sometimes bypass the bios. And if thats no good start it in safemode by pressing f8 before it loads. If all else fails you may have to get another chip.
Mar 23, 2011 | Toshiba Satellite M35-S359 Notebook
Oprating system not found on my toshiba satelitte m35-s359
You typically get that message when the hard drive has crashed or if you're lucky there is a cd in the laptop.
Did you have any important information stored on the laptop like pictures and documents?
Mar 10, 2011 | Toshiba Satellite M35-S359 Notebook
Take care.
May 28, 2010 | Toshiba Satellite M35-S359 Notebook
Clock Issue
I would recommend getting your laptop professional cleaned first before trying to replace your battery.
Replacing your battery on laptops is not always an easy task and can require several hours of labor.
Please visit the following link for access to a replacement battery
http://www.google.com/search?num=100&hl=en&safe=off&client=firefox-a&hs=CpO&rls=org.mozilla%3Aen-US%3Aofficial&q=Toshiba+Satellite+M35-S359+cmos+battery&aq=f&aqi=&aql=&oq=&gs_rfai=
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 23, 2010 | Toshiba Satellite M35-S359 Notebook
How can i hook my laptop to my tv with a s-video cable? a toshiba satellite m35-s359
Yes usually with an S-vid cable with the RCA outputs.
Some laptops have DVI output which is top quality so if it has that port then get that cable.
Ensure it also matches the TV If DVI is fitted.
May 18, 2010 | Toshiba Satellite M35-S359 Notebook
Toshiba M35 S359
This code sound like a power supply or battery depleted code.
Your Power adapter may not be charging the battery. The battery made have reached "end of life".
Mar 28, 2010 | Toshiba Satellite M35-S359 Notebook
Jan 04, 2010 | Toshiba Satellite M35-S359 Notebook
How to obtain windows xp install cd to restore to factory setting
hi
regarding battery u need new battery
and regarding battery u can buy it from market or u can download it from the following link http://www.softwarepatch.com/windows/xpsp2.html
Jun 25, 2009 | Toshiba Satellite M35-S359 Notebook
Replacing M35-S359 motherboard with one from S320?
If the M35-S320 case is OK and the M35-S359 screen is OK and will fit the M35-S320 then I would swap the LCD screen lid and inverter over to the M35-S320 including the hard drive from the M35-S359.
It would be less work and with luck it might boot up, if not you might be able to do a system repair, worst case, you will need to reinstall Windows. Plus you have a spare drive from the M35-S320 which you can use as an external hard drive with an USB hard drive adapter case.
Jan 29, 2009 | Toshiba Satellite M35-S320 Notebook
Computers & Internet Logo
David Payne
David Payne
