My vst system link get deactivated by too many errors every minutes
CAN ANY OF YOU ******* IDIOTS JUST ANSWER A GOD **** QUESTION.. ****!!!! IF SOMEBODY JUST SAYS " HEY THIS IS HOW U SOLVE THE PROBLEM" PPL LIKE ME AND LOKKESRATTAN WOULD HAVE A EASIER DAY.. ****, JUST BECAUSE IT COST THOUSANDS OF DOLLARS AND COMES WITH A MANUAL DOESNT ALWAYS MEAN THE ANSWER IS IN THERE SO WE USE THE INTERNET TO FIND IT!!!... ****, YOU PEOPLE ARE ANNOYING.. IF U NO THE ANSWER TO THE PROBLEM SAY IT, IF NOT, JUST LEAVE THE ******* PAGE!!!!
Posted on Aug 14, 2011
Is the ensoniq mr61 compatible with windows 8? Is there a device or upgrade for this?
Supported Operating Systems and Hardware MQ Essen
tials
Midi
Quest
Midi
Quest
Pro
Info 32-bit Windows support: Win 8, Win 7, Vista, XP checkyes.png checkyes.png checkyes.png 64-bit Windows support: Win 8 x64, Win 7 x64, Vista x64, XP x64 checkyes.png checkyes.png checkyes.png Windows Midi Quest x64 with x64 plug-ins to support 64-bit VST hosts checkyes.png Intel Macintosh systems: OS X 10.9, 10.8, 10.7, 10.6 and 10.5
Check this link
May 29, 2014 | Computers & Internet
Cubase studio 5 has deactivated the VST system links due to too many internal errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
Oct 08, 2013 | Lexicon Omega Desktop Computer Recording...
Vst system link errors
May 23, 2012 | Lexicon Omega Desktop Computer Recording...
Powerbook G4 will not start from Smart Disk VST
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
Nov 05, 2011 | SmartDisk VST (FWCDRW-F) CD-RW Burner
When I try n open a session on cubase le4 I get a warning saying the vst system has too many errors and the session never opens... what could it b?
Sounds like you have a corrupt auto load. You need to recreate your default song (the blank one that opens when you load). that should cure your problem.
Good luck
Sep 14, 2011 | Tascam US-144 Sound Card
I can not get my bluesnow ball microphone to connect with my cubase studio 5
How to use USB device like a USB microphone, or USB guitar Cable in CubaseThis was a frustrating problem for me and I found most forums did not really helpAfter hours of annoyance I finally figured it out and it's a very easy and quick fix.1.Download free ASIO4ALL 2.8 here http://download.chip.eu/en/ASIO4ALL-2.8_108174.html and then restart cubase2.Click Devices and Open Device Setup3Click Vst Audiobay and Change the Master ASIO Driver to ASIO4ALL v24.Underneath Vst AudioBay Click ASIO4ALL and Click Control Panelhighlight All devices you wish to use and Enable them.5.Still in Device Setup hit VST Inputs and check to make sure all Devices are there6.Exit Device Setup and under the Devices open VST connectionsClick add bus, and Add Busses. Your Sound Device should be the first Bus that pulls upand the other busses will automatically be whatever the USB Devices you enabled were.7.Last thing and very important, when you open up a new Audio track Right click where it shows Stereo in. Your usb devices will start at stereo in 2 and depending on how many you enabled go up in numbers from there.In my particular case I have a Blue Snowball usb mic as my first Device (stereo 2)and a Usb Guitar Cable interface as my second device (stereo 3)*If you would like to hear and test your sound prior to playback simply click the monitor button and unclick it at playback.That simple, there you go.This will work, takes and takes less than a minute.
Oct 12, 2010 | Blue Microphones Snowball Professional...
Hello
PLZ UNINSTALL NUENDO FIRST. THEN INSTALL MOTU DRIVER. NEXT POWER MOTU.
NOW YOU SETUP NUENDO VST AUDIOBAY FROM DEVICE SETUP. CLICK VST AUDIOBAY AND SWITCH IT.
NOW YOU CAN SETUP MOTU AUDIO.
OK
Apr 30, 2010 | Steinberg Nuendo 3 for PC
Tascam us-144 mkII now working with cubase le4
better , you can use it by nuendo or cubase sx. over all you try it cubase device setup and click vst system or switch vst audio bay. for more help call me +8801711904316
Apr 05, 2010 | Tascam US-144 Sound Card
Cubasis vst version 5 serial number
If you go to
http://www.steinberg.net/en/support/steinberg_support_creative_tools/cubasis_vst_faqs.html
you will find a serial number for Cubasis VST version 5.
Hope this helps.
Feb 15, 2008 | Computers & Internet
545 people viewed this question
k24674
jasbo
jasbo
