Question about HP Laserjet Cp2025n Printer
Cannot print pages from computer. I have to pres ok button on printer
Paper size or type mismatch with printer setting
Posted on Oct 27, 2010
I want to default the setting of epson lx1170 printer
Log on your computer and go to task bar click on start button then go settings p
Click ib printers and faxes right click on your default printer then go properties there will be the option that you cN change on default settings of your printer and if the software is ok still problem persists the turn off ur printer pres Lf button on ur printer den on ur printer its gives uh self test page, after 2 pages off ur printer den on nd check ur issue
Aug 27, 2015 | Epson LX-1170 II Dot Matrix Printer -...
Problem printing on both sides of the page
Just we need to know about your printer Brand & model.Because some model printer have not support duplex printing.Duplex printing printer is very good canon lbp 3300 and hp Laserjet p2250d.Please check it and reply soon.
Apr 14, 2017 | HP LaserJet 1020 Printer
Need to align ink cartridges
Follow the steps to align newly installed cartridges.
  • When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  • Press the button next to OK on the control panel display.
  • The product prints an alignment page.
  • Place the alignment page print-side down on the right front corner of the glass.
When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer
  • Double-click the HP Digital Imaging Monitor icon ( ) on the lower right side of the Windows taskbar.
  • The HP Solution Center displays.
  • In the HP Solution Center, click Settings . Then click Printer Toolbox .
  • The printer Toolbox displays.
  • Click the Device Services tab.
  • Click Align the Print Cartridges .
****If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 05, 2013 | HP PSC 1210 All-In-One InkJet Printer
I have HP 6540 ...... the black cartridge was emptry ( my son do this :) ) ...when i refill it (and put it in the printer) indicator says that the cartridge is empty. When i pres the buttons on the printer...
each cartridge has its unique serial number,
printer remembers him,
is absent sensor of the ink level determination in you cartridge. You can to print, but message will say to you "EMPTY CARTRIGE".
this warning function can be disconnected by you in printing driver.
If you bathe new cartridge, that level will show full.
If afterwards put(deliver) old , that he will show that empty.
Printer can have a memory about two or three last cartridges.
Dec 17, 2009 | HP DeskJet 6540 InkJet Printer
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I TRY TO PRINT ONE PAGE AND THE PRINTER PRINTS MULTIPLE PAGES AND IT IS ALL GARBAGE.
This happens when you have the wrong driver software loaded into your computer. Try printing a test page directly from the printer. Hold the 'page feed' button as you power up the printer. This will tell you if the printer is working. If this is ok, try a different print driver in your computer.
Sep 09, 2009 | Epson Stylus Color 740 InkJet Printer
Paper jam after 1 page prints
fuser paper out sensor faulty.req new fuser.
Jun 20, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
HP Officejet 6210 All-in-One - Conformation Page
yes
press setup
pres 2 and then press 1
this seletcts print report and then select Fax Report setup.
press and scroll to the to the report type you want.
press OK to select the report
Jan 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
C5180 printer won't print.
I just had this problem and here's what I did (with a little help from a previous yahoo answers post)...
1. Turn printer and computer off
2. Disconnect printer from computer
3. Unplug printer completely
4. Hold power button on printer while plugging printer back into power source. Maintain holding power button in until printer cycles completely (Ihave no idea if hold it actually does anything...but I tried it and it worked)
5. Turn printer back off (which actually may happen anyway when you finally release the power button)
6. Reconnect printer back to power source and computer.
7. Power both back up.
That should do it hopefully. Also make sure your printer cartridges aren't totally out. It won't let you print if even one of them is completely empty.
Good luck.
Aug 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Laserjet Cp2025n Printer Logo
126 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
