Question about Kenmore 23822 Top Load Washer
I have a Kenmore 80 Series Washer Model 238321G0 It will not spin when going into spin cycle without lifting the lid. Once you lift the lid it will spin every time. Been using it that way for a couple years. Is there a fix? Tired of running to catch the spin cycle.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission
"Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Oct 07, 2010
Testimonial: "Thanks just ordered Neutral Assembly and Entire trans Just in case. I can send it back if it is not needed. "
After rinse cycle won't washer won't spin
Sound like it could be a lid safety switch.
May 24, 2014 | Kenmore 22422 Top Load Washer
My Kenmore 26442502 top load washer will not kick into the spin cycle after it agitates. Just kinda humms. As I open the lid while it should be spinnning, everything stops, like it should. Once I close the...
Hello Dbriner,
It would appear that the lid switch is defective and is in need of replacement. I included a video showing basically how to replace it (It is a series 80 machine but that is minor).The steps are the same.
Your part can be found here for $29.65 +Shipping
Good Luck!
Rich Lilja Kenmore Washing Machine Lid Switch Assembly WP8318084
May 20, 2017 | Kenmore 24032\24036 Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not spin sometimes/ Safety switch broken and I need to lift the lid to install new switch. Any suggestions?
If you are talking about replacing the lid switch, the following link explains how to remove the washer case to access:
http://www.fixya.com/support/r385198-replacing_lid_switch
The intermittent spin cycle problem is generally a clue that the lid switch may be malfunctioning in some way. If you've already diagnosed this to be your problem, then the link I provided will give you the necessary guidance to complete this repair. If you have any questions along the way, please let me know. I hope this is helpful to you.
Jun 03, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Kenmore Model 80 get stuck after agitate and will not spin out
I have seen this on the same model recently, try lifting the lid during the neutral drain and reclose, if it engages spin then. then most likely your timer is bad too. The timer after two minutes of "neutral drain" will stop the motor (same effect as lid sw) then restart after a pause with spin/drain. this pause shifts the transmission to its next cycle which is spin. I found burned contacts in timer. Your timer list price is over $100 but easy to replace
Nov 24, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
Kenmore 23822 Top Load Washer Logo
417 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
