Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishlex Global 300 Dishwasher
I have used both the powder form and tab form of detergent in my dishlex global 300 dishwasher but when the cycle has finished and I go to up-pack the dishwaster the detergent lid is open but the powder form is rock solid or alternatively the tablet form doesn't disolve.
I have cleaned out the filter etc.
can someone please assist me.
Many thanks
  • juliafhperry Jul 13, 2008
    same problem, right to the solid blocking!
    So I changed to a liquid, and now that leaves a heavy residue in the lock section of the soap dospenser.
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
Posted on Sep 15, 2008
Just bought a house with dishlex global 300
and thecycle starts and the floor becomes a river..
im guessing door seal???
but the next time i use it i gave the door an extra push to close firm and it didnt wash the flooor..
Posted on Jun 12, 2010
  • 833 Answers
Start the cycle and then stop it by opening the door slowly. Is there water in the bottom of the unit? If not...and I'm betting not (or not much)...you have a water issue. Check your:
  • water inlet valve
  • float switch (the water float should move freely on its shaft) or the water depth pressure switch - if there is one - is not reading correctly...replace it or unkink the tube
  • timer
One of them is a problem.
Posted on Jun 02, 2008
Recently bought a house , which has a Dishlex Global 300 dishwasher ..problem =
!/ the tablets dont leave the tablet container and end up soild,
2/ dishes are not clean...and have to do them again..
I have cleaned it out with dishwasher cleaner and checked every where ..
christina
Posted on Sep 09, 2009
  • Dave Harrison
    Dave Harrison Oct 29, 2013
    Got the same problem. cleaning the top spray arm holes of debris helped but still happening regularly. Now I've proved the arm is not rotating - there's some sort of problem with it being tight but I can't see why that is so
2 Suggested Answers
SOURCE: Detergant door solenoid
detergent door does not open
Posted on Sep 22, 2009
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
The detergent dispenser on my dishlex global 300 dishwasher not opening during the cycle. How do I fix this?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 09, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Not disolving powder thru cycle
This may be a problem with the powder that you are using. It may also be a problem with the temperature of the water that is coming into your machine (not hot enough).
You may want to try a gel type detergent.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Electrolux Dishwashers
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
What detergent is best to use in a dishlex global 300 dishwasher? i just inherited one second hand and have to buy detergent. can i use tablets?
Greetings to you your best way to buy dishwasher detergent is jell form it disolves and generatews even cleaning and better to have spot free dishes if you have hardwater put in a squeez of lemon juice in the tray for jet dry it works xcellent
May 31, 2008 | Dishwashers
Tank is leaking
Is it the tank or just the door seals? Ours was leaking recently, there was an obvious tear in the door seal. Once fixed no probs.
Nov 02, 2007 | Electrolux 23 in. ESL624 Built-in...
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
1,475 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
