Question about LeadSinger Wireless HiFi Remote Duet Mic for LS-3700 Karaoke Unit Microphone
Are chips for the leadsinger 3000 compatible with the ls3700
Ar all chips compatible with karoake systems
no
there are various issues , model of the system the make ( magic sing will fit magic sing ONLY )
if laungage font is different example hindi etc then also it will not work
chips made for very old models may not work on new systems
example ed series chips may not work on KV and KH series
for more please email me on mumbai11@gmail.com
Jan 07, 2015 | LeadSinger Audio Players & Recorders
Lyrics stick when playing songs on Leadsinger MVK2
Firstly all lines have to be timed. Then they will scroll. Other issue is the microphone is 16 Bit and we use mostly 32 and 64 bit file names as well as allowed characters within a page. 16 bit dos is limited characters specially comma or ( ) [ ] } : # $ so on will not work with this mic. Convert what doesn't work with FileEncConverter (available on web) and they will work. This program removes what mic can't handle.. Good luck
Jun 25, 2012 | LeadSinger MVK2 Consumer Microphone
Power lost on Main Microphone.
sound like you've been f#$^%d I suggest you boycott the company if enough people do it they will be forced to bankrupt then the government can bail them out and own the company this would give them the power to do things like fire the c.e.o.... still doesn't help your situation but it's fun to watch on tv
Apr 29, 2009 | LeadSinger LS-3000 Consumer Microphone
Leadsinger 3000 series
throw it in the garbage. its a trash.
Apr 06, 2009 | LeadSinger LS-3000 Consumer Microphone
Leadsinger microphone..... no sound on tv ..microphone seems dead
Did you go to Leadsinger.com and follow their instructions on doing a Hard Reset? It might help. I had the same problem but with a scrambled picture and no sound. The reset restored the picture but not the sound. Thats when Leadsinger returned it for a reconditioned one that worked worse than the first one. Now I get no response from them.
Feb 26, 2009 | LeadSinger LS-3000 Consumer Microphone
No power
did you make sure all the song cartridges are installed in the right direction? If they are not, then no power.
Jan 01, 2009 | LeadSinger LS-3000 Consumer Microphone
LS 3700 Leadsinger Microphone
We had the same problem just this weekend. However, we investigated it ourselves and discovered that you can take the microphone apart by unscrewing the two small screws inside the mic, under the music chips. Once the screws are out pry the two halves apart very carefully. Once we were inside, we discovered that the soundcard was loose and all we had to do is plug the sound card back in. Close 'er up and start up the show. Good Luck!
Nov 10, 2008 | LeadSinger LS-3000 Consumer Microphone
My video isn't working right
I just fixed my problem and the mike is working great! Try holding the number 9 then press and release the power button. I found this on the Leadsinger FAQ section and it worked. I'm pretty happy, as I really enjoy the chips I have for the mic!
Mar 28, 2008 | LeadSinger LS-3000 Consumer Microphone
LeadSinger Wireless HiFi Remote Duet Mic for LS-3700 Karaoke Unit Microphone Logo
62 people viewed this question
Top LeadSinger Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
