The laptop takes along time to boot then after booting then after booting it shows blue screen then hangs.
  • 358 Answers
This is likely to be as a result of your processor over-heating,
maybe because of your environment, or because the fan is not
cooling the processor properly again.
Therefore my suggestion would be for you to unscrew your laptop
(If you can do it by yourself), and try to clean, or better still replace
your processor fan.
Also clean the air-vent where air is supposed to enter the laptop
If you cant do it by yourself, you can easily get a technician to do
it for you.
Also, remove all your RAM(Memory Sticks), and clean the tip of
the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put
on your system and see if it works, then do the same thing with
the other one.
If the two of them works, them insert the them all. but if it is just
one that worked, just remove the other one that is not working and
replace it.
If the two of them are not working, then try to get a ram of the
same type to test it with, either from a friend or a technician.
I have actually had the same case before, and after doing what
I've just told you, it stopped behaving like that.
Then always make sure that your laptop is in a well ventilated,
cool environment and that the environment is free from dusts.
Kindly let me known how it goes after you've tried this.
Hope this helps you out.
Posted on Oct 07, 2010
  • 29 Answers
The problem may be with your RAM just get them checked whether they are properly working or not.......
www.hiddendragons.tk
My computor shows a blue screen when switch on please tell me wats wrong.
blue screen is a hardware issue. it could be anything plugged in inside. if you know how to strip a pc then you have to start taking things out and trying to boot. start by unplugging anything you have plugged into the back and only leave keyboard and mouse in. try to boot. then try taking out any cards plugged into the board. try to boot.if there is only the basic components left and it still wont boot you will have to get it checked out by an expert ( unless you have these parts as spares then swap them over 1 at a time and trying to boot each swap ) something on your board has gone and you need to track it down
Apr 30, 2015 | Computers & Internet
My laptop is on but the screen is blue and won't go to the desktop
A Mac that shows you a blank blue screen instead of logging you in may be afflicted by a malfunctioning startup item. Most people have a number of programs that start up whenever you log into your computer, and it's likely that one of these programs is causing issues. The startup item is unable to load, and so it causes the rest of the computer to hang.
In order to get your Mac past this hanging blue screen, you need to boot into safe mode and figure out which startup item is causing problems. The Apple Support article "I see a blank blue screen when I try to start up my computer" tells you exactly how to go about this procedure. Basically, you must remove all your startup items and add them back in one-by-one, rebooting each time until you find the one that causes the hanging blue screen.
Dec 28, 2010 | Computers & Internet
The computer is on, but the screen is all blue
Dec 28, 2010 | Apple MacBook Mac Notebook
Blue screen
hi is this blue screen is always be previewed when u turn on ur laptop or it appears when ur laptop boot
if this happens when ur laptop boot to ur windows then ur screen will show a blue screen with errors code that show there is a problem with ur pc and this happens to prevent a harmful to ur laptop
so if this a problem write me the overall error message or take a picture of ur laptop when it shows this error message with blue screen and send it to me here or via mail to ghassanalasmar@hotmail.com which is appeared in ur screen with blue screen to tell u how to fix it
Aug 09, 2009 | Toshiba Qosmio G15-AV501 Notebook
M1400 Tablet-PC doesn't boot anymore. Hangs up while loading Windows. Shows blue screen with message "Windows has detected...." for half a second and restarts itself.
get a hirens boot disk. that will fix ya right up. boot from the disk. choose either option boot windows xp mini or from boot disk. do not choose the option boot from hard drive or you will get no-where.
Jul 15, 2009 | Motion Computing M1400 Cent PM 733...
I was playing online games on my sony vaio. Suddenly I got blue lines on the screen and the laptop stopped responding. So I tried restarting the laptop but I get blue thin vertical lines before the laptop...
Blue thin lines before it boots will rule out an operating system or driver fault. So it would appear something in the machine has failed.
Do you have a VGA monitor you can connect to it and see whether it shows the fault? This will show that if the fault also shows on the external monitor, it is likely an electronic fault on the main board, whereas if it works on the external monitor but not on the built-in monitor, my guess would be the cable that goes from the main board up through the hinge of the screen into it, or a connector, or an actual fault with the LCD display.
Windows booting normally once the display drivers were disabled indicates to me that Windows is no longer detecting the faulty display and therefore boots normally - possibly pointing to failed electronics in some way. It could even be corrupt BIOS that controls the video or something along these lines, though that's unlikely.
Good luck, either way it sounds like it's off to a computer repair shop. Is it under warranty?
Apr 27, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Apr 01, 2009 | Toshiba Qosmio G35-AV600 Notebook
While booting hang , only showing f10 boot screen .
Here it is.
1. When asked to press F10, do it! It will take you into bios setup, then load "bios defaults", then "save and exit"
You should also try to update you bios and all your drivers. Come back here for instructions if #1 do not solve your problem.
If you find my solution usefull, please rate it at FixYa.com
Thank you ;)
Mar 28, 2009 | HP Compaq nx6110 PC Laptop
Blue screen
you have a virus on the laptop. you will need 2 take it 2 a professional to get the virus removed.
Jul 29, 2008 | Compaq Armada M700 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
