Back to:
Tags:
Gateway Internal Drive Case
No sound (by 2 users)
posted by ingeborg329 on May 29, 2008
i installed a new dvd/cd rw to my gateway micro tower and i can watch a movie but there is no sound i do have sound in everything else what did i do wrong?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Aug 01, 2008
ESS elitegroup no sounds
Solution #1
posted on May 29, 2008
Not Rated (0)
sparky1500
Rank:Wiz Wiz
Rating: 84%, 56 votes
you have to get an additional wire to run from the drive's audio out to the sound card's aux in
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on no sound:
I don't want to Accept this solution
Can you Help with these Drive Cases problems?
Drive Cases
I have a bytecc backupstar me-808 and the drivers will not...
Drive Cases
I need to remove the hard drive from a Maxtor personal...
Drive Cases
I forgot to mention that the old hard drive in the...
Drive Cases
i need to fit seagate hard diive into new enclosure
Drive Cases
the connector to the plug appears damaged, blue light...
Loading problems.
Repair Service
Find Drive Case Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
