Question about Brother XL-5500 Mechanical Sewing Machine
Hi, My sewing mechine is brother lx-3125 and my problem is getting loose stitch on both sides of fabric when i set stitch is 10 and tension 4-6..and also i am getting loose stitch on other no also like 9 and 8.. I already cleaned everything and did oiling but it doesn't work...please tell me the solution for this..
    Genius:
  • 1,788 Answers
Most likely your machine is not threaded right, read your manual closely and double check yourself. Rethread your machine, no mixed thread use same weight, color does not matter but weight does. With your presser foot down, your top thread should be had to pull, with it up it should pull freely. Make sure your bobbin is wound evenly, and on a fresh bobbin. Then put in a new needle. Now, if the machine is still acting up, it may be your timing. You can call Brother at 1-877-276-8437 customer support. if you need a manual, go to www.brother-usa.com. I am answering this for free just to try to help you. Good luck
Posted on Oct 07, 2010
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
Ho can i get bobbin tension right?
Bobbin tension depends on the thickness of the fabric that you're sewing on. A cotton fabric should have medium tension...but a heavy wool would need a looser tension. Best way to get the tension right is to take a few stitches, then look at the bottom side of the fabric. If the threads are loose, then tighten the tension one notch or number. Sew a few stitches, then test again. If the fabric is pulling up tight, then loosen the tension and check again. Top stitches and bottom stitches should both be the same.
Jul 04, 2014 | Husqvarna Freesia 415
The stitches on my brother 3125 sewing machines are loose. On the top and bottom. Ive tried to redo my stitching and nothing has worked . Please help !!!
Make sure presser foot UP position. Rethread making sure thread is taut so it can locate tension slots. Rethread needle making sure its up in the needle bar shaft--flat side BACK--thread goes through needle eye front to back. Tension: 4 Jimmy
Apr 04, 2012 | Brother LX3125 Sewing Machine
What setting do i use for working with silk on a brother xr52 don't have manual
You can download the manual for your machine from the Brother site, link is
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000061/xr52c65txl64526562ug01enesfr.pdf
There are lots of weights of silk fabric but I'll assume you are working with something soft and silky like a silk charmeusse or silk georgette.
You need to stitch seams with a straight stitch and use a new sharp needle size 70 or even 60. Change the needle every 4-6 sewing hours or if you hear squeaking or popping; throw away the blunt one.
Use a quality polyester thread like Guttermann, Mettler, or Metryosene. Start with stitch length on 2.5 and stitch width zero (straight stitch). The normal metal presser foot is probably best for this. If the fabric is see through you may wish to do french seams to encase the raw edges. This is where you sew wrong sides together, then turn and stitch right sides together, if you have never done this instructions are here http://sewing.about.com/od/techniques/ss/frenchseam.htm.
Also pay carefull attention to your bobbin winding, my tip for this is here
http://www.fixya.com/support/r10598580-winding_bobbin_correctly
as winding the bobbin smoothly and evenly is essential to quality stitched seams.
Always press every seam as you sew, dry iron, silk setting. Press each side of the seam, then press the seam allowances open, this sets the stitches into the fabric.
If you find that the seam is pulling up you can try loosing off the top tension by a half number (turn it down to loosen) and shorten up the stitch length a fraction to 2.2 or so. But you don't want it too small as if you need to "unsew" ie unpick, you'll never see the thread.
Use a lighweight interfacing if the pattern requires it; I'd use a fusible but very lightweight such as Pellon Featherweight.
Happy sewing.
Sep 02, 2011 | Brother VX808 Sewing machine
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
Tension on reverse side of fabric is too loose-
Set the tension back to the recommended setting (in manual). This is usually around 4.
Always thread the machine with the presser foot up as this allows the thread to properly "seat" into the tension control.
Mar 23, 2010 | Brother XL-5130 Mechanical Sewing Machine
I am sewing on 100%polyester silk and using a 65 needle and the tension is on 4.2, stitch length 2. The fabric keeps wrinkling. I've tried rethreading, checking the bobbin and changing the tension. Nothing...
There is a pressure adjustment for the presser foot.
This is usually on top of the machine, over the presser foot.
If it resembles a screw head on this model - a dab of nail polish or mark of a sharpie will help when you reset after sewing sheer fabrics.
If you move the adjustment to the left it will reduce the pressure and should also reduce the wrinkling.
Adjust and then test on a sample of the same fabric you will be sewing.
Be sure to re-set after sewing thin fabrics.
Refer to the manual or download a free one at Brother's website.
Feb 22, 2010 | Brother XL3750 Mechanical Sewing Machine
Brother XL-5500 Mechanical Sewing Machine Logo
305 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
