I am working on a Peavey Classic 30 amplifier. It is completely dead, no sound. All the tubes light up. The 12ax7 tubes don't seem to glow as bright as the L84 power tubes.
  • 1,512 Answers
Hi directmusic
You can get a circuit diagram from here.
The 12ax7's will not glow as bright as the EL34's . Is just the nature of the tubes. The latter being higher powered and the 12ax7 low power. The EL84's as output tubes will always glow brighter, and often even with a dull blue glow about the plates from the higher voltages made available to them. If the plates them selves are glowing red(inside the EL34's). then you have a bias problem. Be careful running the amp in this condition. Do some static checks with the amp off looking for failed components about the bias and screen control stages. .
Start by checking all the DC voltages first. The circuit diagram i supplied the link for has voltages marked for you to check. A common problem with this amp is the 390 ohm 5 watt resistor going open. A faulty output tube(s) may also have caused this. I would replace the output tubes anyways for a good repair.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
  • Graeme Ross
    Graeme Ross Jun 05, 2008
    Hi, just a quick followup to see how you got on with your
    problem. If you still havent got it sorted, let me know, I am happy to
    do some more research and offer some more information and solutions. If its fixed...
    excellent!! A FixYa rating from you will close this unrated solution
    for me. Thanks for using FixYa. I am happy to answer any other
    questions you may have.
    regards
    robotek
Having some negative issues while playing guitar through my amplifier.....
Have you checked all the other amp tubes? You may have a bad 12AX7 or 12AT7 tube.
Aug 02, 2014 | Peavey ValveKing 100w All Tube 212 Combo...
While playing sound totally stopped. stsill getting power. 2 of the 3 pre amp tubes not glowing could this just be a tube problem. I have not changed the tubes since owning it. 5 years.
The preamp tube fillaments are run from DC with all three in series. The 36 volts for the heaters come through a 15 ohm power resistor. Check voltage across C46. You should find about 36 volts. if that voltage is there, one of the 12AX7 tubes has burned out one of the heaters and like a series Christmas light set, the string is all dead. Here is the problem: Various brands of tubes will vary in heater current and as such replacing one of a different brand may cause it to not take its share of the heater voltage, either more or less. So sorry to say, you should replace ALL three of the 12AX7's with the same brand tube and preferably from the same production lot at the same time. If you happen to find the voltage across C46 is way below the 36 volts, cease to use the amp until the cause is repaired since this voltage is also used in biasing the power tubes. The arrangement they have used in this amp is stupid as far as the heater circuit and having these in series... I would have fired the designer.
Apr 25, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
After playing for a while, approx 15 min, the volume dies away leaving some sound but greatly reduced. It then gradually returns to normal volume after about 3 mins. Otherwise all other functions seem to...
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Mar 29, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
My peavy vk 2x12 have a dirty distortioned sound in the clean chanel, i'd took a look at the back side and i saw the problem could be the 12ax7, one looks ok, one is dead, have no light while is turn on,...
* ALWAYS UNPLUG YOUR AMPLIFIER BEFORE REMOVING TUBES *
If you can see that a tube is definitely not lighting up then it may be blown. If this amp has seen regular use then it may be time for a new set of tubes. Try replacing the 12AX7s first before committing to a new set of 6L6s. Though, if you have the cash available, a new set of power tubes isn't a bad idea either. I would advise you to do the preamp tubes first and play through the amp for a few days first before changing the power tubes.
Keep in mind... if a tube (or tubes) has blown, there could be another issue in the circuit. Swapping in a new tubes is a quick way to determine that. Then it would be time to take it to your local repair shop.
Good luck and keep rockin'!
Feb 21, 2011 | Peavey ValveKing 100w All Tube 212 Combo...
I have a Peavey ValveKing 112. It seems like it just takes forever for the tubes to warm up. For like the first hour that it's turned on the clean channel seems fine, but the second channel doesn't work....
Buy ONE new 12AX7 and try it in location V1 and if it doesn't help, try it in V2. This tube has TWO heaters in it and if one is intermittent that could cause your problem. The vibration MIGHT be "fixing" a briken heater after some time.
There are MANY components that could cause this, so you might have to take it in for repair if it isn't a simple tube problem. Since it works on the clean channel, V3 should be OK.
Feb 11, 2011 | Peavey Valveking 112 - Tube Guitar...
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
Peavey classic 30, new tubes and PT with absolutely no sound
I'm not sure what "PT" is , but the heater voltage is separate from the other voltages required for this unit to function properly. Please note that with tube systems, there are voltages in the 300-400V range that can cause injury. If you do not have experience with tube based electronics, I would suggest that you bring this to a service center for repair.
Please update this with what you mean by "PT" and we'll continue from there.
Thanks,
Dan
Nov 12, 2008 | Audio Players & Recorders
110 people viewed this question
 Grubhead
Grubhead
