Question about Weller WPA2 Pyropen Professional Self Igniting Cordless Butane Soldering Iron
My Weller pyropen does not ignite all of the time despite it having gas and a really good spark from the igniter. Is this a common problem and if so how do i resolve it It will also turn itself off if you turn it side on.
Hi all, Just bought a WSTA6 iron, also wouldn't ignite reliably - just figured out you have to block the little air vent holes either side of the start switch with thumb & finger for 2-3 secs. while starting - 2-handed procedure :( -Now works like a charm :)
Couldn't find this info anywhere ???
Scotty
Posted on Jan 26, 2012
I have the same issue. I overcame it by replacing the tip with a new one. I estimate I get about a year from a tip. I cannot tell why the old tips make the pyropen hard to ignite.
Posted on Apr 03, 2011
    Problem Solver:
  • 10 Answers
You can try replacing the burner (part # WPAE). It's available at MCM (http://www.mcmelectronics.com/product/96-1260).
Posted on Mar 11, 2013
  • Phil Mar 11, 2013
    Sorry -- meant to say replace the Ejector (WPAE). The burner (WPAB) is probably not needed if you're getting a good spark (although, cleaning it might help).
    Problem Solver:
  • 9 Answers
On my P2K I just found adjusting the gas on switch (not the knob on the bottom) while igniting worked for me . Even new tips weren't working for me the normal way
Posted on Nov 04, 2012
Worked about month rs after that this is 2nd of put new tip on have spark n gas not worth buying .
what do you want , look at the size of the tank and know it will not last for months on end
Jan 23, 2016 | Weller WPA2 Pyropen Professional Self...
2002 saturn l300 doesnt want to start I want to know if anybody knows where to start looking for the problem besides the fuse box. It has a brand new battery.
If it won't start, it is very likely either fuel or spark is lost at the engine. Is the engine getting gas to it from the gas tank? Do you hear the fuel pump turn on for 2 seconds with the key in on, not start? This 2 second period is to put pressure in the line and to the fuel injectors.
If gas is getting up to the engine, next check for spark. Buy a cheap spark tester, hook it to a spark plug wire and crank the engine over. If ignition system is good, you will see a blue, snapping spark on all of the spark plug wires. If you have spark, next check the fuel injector circuit. Post back if you need help with that.
If you have no spark, aha! your ignition system has failed. Now you really do need to check all your fuses before proceeding. Most common failure with no spark is an ignition coil, a bad ignition control module, or a bad crank position sensor. Many other possibilities, but those are the most common.
Oct 04, 2014 | Cars & Trucks
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
Heater is a Dayton 3E-133E used very little. weak spark won't ignite gas
yes they do go bad some times they have a hairline crack in them and the will spark but never light the gas they have drove me nuts many a time , for no reason they will not light , then replaced it and wham it works .
Mar 01, 2017 | Dayton Heating & Cooling
Misplaced Manual, what butane container to get.
Any butane will work, but the big name-brands are usually filtered better and less likely to cause problems. The biggest issue is the nozzle -- there are a lot of different sizes. Any Weller butane can will fit perfectly (usually cheapest at the local Sears store), but any can with multiple adapters will also work.
If you have an old can that fits, save the nozzle when it's empty. It should fit a different can if you can't find a can that fits the tool.
Jun 04, 2012 | Weller WPA2 Pyropen Professional Self...
My Pyropen will not ignite
Not enough information. That's an extremely vague description of the problem. There's no way to suggest a fix without knowing more about it.
Does it spark?
Does butane come out of it?
Is the cylinder full?
Do the switches move properly?
How old is it? How much use has it seen?
Is it an intermittent problem, or constant?
Apr 12, 2011 | Weller WPA2 Pyropen Professional Self...
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
Weller PSI-100K doesn't ignite. I have taken off the tips and checked. There is a spark and I can ignite it minus the tip. It only then stays ignited if I keep pressure on the ignition switch. Once that is...
I have the same soldering iron and have found for this problem, the replaceable tip has worn out.
All you need to do is buy a replaceable tip of your choice. The tips are a consumable part that wears out.
Jan 09, 2011 | Weller Portasol Pro Cordless Butane...
My Pyropen WPA2 will not ignite I have changed the gas ,it has Butane UN1950 in now and is Half full
Does it spark?
Does the butane come out?
How old is it, and how much has it been used?
Did you put cheap butane in it at some point?
Sep 10, 2010 | Weller WPA2 Pyropen Professional Self...
Weller WPA2 Pyropen Professional Self Igniting Cordless Butane Soldering Iron Logo
3,013 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
