Question about Panasonic NN-S541 Microwave Oven
Microwave shows code h29 does not work do you know what this means??
What does H97 mean?
It is an error code that means ether the magnetron or the inverter is bad.
Oct 16, 2014 | Panasonic NN-SD372S 0.8 cuft 950-Watt...
Maytag Microwave MMV4203DB00 HAS A 5E CODE AND IS NOT WORKING AT ALL WHAT CAN I DO?
Hai,you unplugg it for few seconds and reconnect if doesnt clear its a pc board problem which will need atechinician
Sep 12, 2014 | Microwave Ovens
My samsung microwave model SMH718 keeps showing an error code -SE- and keeps beeping in 4 beep intervals. How can I correct this?
I had the same problem, I changed the daylight savings time on mine and it worked untill summer, then it happend again. Finally mine quit working altogether. P.S. when this first happend samsung didn't even know what the error coded meant. It is an engineering code, meaning service engineer I believe. If it is beyond the year warranty your hosed, it would cost so much to try and fix your better off buying a new one.
Oct 25, 2010 | Samsung Microwave Ovens
Microwave model UMC5200BAB display is locked. After power reset per instructions display shows error code -SE- or -5E-. Somtimes pressing Stop for few seconds bring the clock back and it work fine for a...
"SE" error means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs
Oct 08, 2010 | Microwave Ovens
F3?
Key panel (touch pad) shorted(f-3)
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jun 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Mar 12, 2009 | LG LMV2083SW Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
My microwave shows a H98 error code . Does anyone know what that means ?
That would be a Panasonic inverter failure code, but please reply back with your brand and full model number.
May 05, 2008 | Microwave Ovens
Kenmore Microwave Problem
"d" may mean demo mode.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
Oct 13, 2007 | Microwave Ovens
Panasonic NN-S541 Microwave Oven Logo
47 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
