Question about Canon iR 2016i Black and White Copier
DP thoroughly cleaned. Fresh toner inserted, still showing out of toner, change toner.*28* pressed and Clear all. Still problem persists.
    President:
  • Canon Master
  • 1,447 Answers
May be toner not supply.If you fix this problem you try to clean toner supply gear or brush.some times it very jam than can not toner supply.
Posted on Oct 10, 2010
  • Sazeed Computer
    Sazeed Computer Oct 10, 2010
    or toner supply motor is out of order
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
Oct 31, 2014 | Office Equipment & Supplies
Is there a way to clean a dp c266 toner waste cartridge
Yes. Remove 1-screw and black tape. Dump waste toner. Blow out clear tube on rear bottom of container.
Jun 13, 2014 | Panasonic DP-C354 Copier
How to clear toner alert
open the front door and close again, wait for toner to load.
if this problem persist,open the front door and remove toner unit,use a flat screw driver to press on the door sensor and check if the toner motor is working properly.
if the motor is in good condtion,service the toner unit and make sure that the unit is toner free and insert new toner.
if this condition persist, enter the sp mode and clear all memory by sp 5801 for mp5ooo, aficio 1035-4545,645,2035,2045,235,735 or sp801 for 1022,1027,1505 and restart the machine.
for aficio 1035-4545,645,2035,2045,235,73 enter sp21093 and 21094 mode before making a copyor else the error sc329 will appear.
good luck
Apr 04, 2014 | Ricoh Aficio MP3350
My copies come out very dirty not clear
CHANG THE CLEANING BLADE AND THE DRUM.
IF THE PROBLEM PERSIST, CHECK YOUR TONER.
OR CHANGE THE DEVELOPER AND THE TONER.
Feb 10, 2014 | Gestetner DSm635 Copier
Replace/install waste toner tank samsung clx-3305fw
I repeatedly tried emptying and reinserting the waste toner tank, to no avail. What finally did the trick was thoroughly cleaning the sensor windows (or whatever you call them) in the side of the tank. These are two small squares of clear plastic (approx. 1/4-in. on a side) side-by-side, with a longer rectangle below the one on the left, to form a sort of inverted "L". I used a Q-Tip dipped in water to swab off the inside surfaces, then the dry end of the Q-Tip to dry them. Shining an LED flashlight through them helped me locate the surfaces inside the tank. Repeat until the Q-Tip comes out clear.
Nov 15, 2012 | Samsung Office Equipment & Supplies
After replaceing the toner cartridge - how do I reset my panansonic dpc264 to show % ava.
Press function key and select counter view. Scroll down until you see clear toner counter.
Jun 08, 2011 | Panasonic DP-C264 Copier
Toner light flashing althougth I have changed the toner and was shaking it before I inserted it..
Toner should be carefully inserted into the Place where it resides.
Improper installation makes this light flashing.
Stpes to be done :
01. Remove the toner gently from the toner drive.
02. Shut down PC and the Dell Printer.
03. Re boot the machine and the Dell Printer.
04. Ensure Power and network cable is installed properly.
05. Use only genuine and Dell Authorized toners in the Printer. Clean the place with nice white cloth with cleaning liquid.
06. Now you can take a test print out.
07. Still the problem persists, please call Printer Service engineer to solve the issue.
Jul 21, 2009 | Dell 1710n Laser Printer
Flashing light, with the words saying clear toner counter, how do I do that?
Shake your toner then press LIFE 2 START. If the problem persist replace your toner then press LIFE 2 START. Your life button is located under the page plate(flip it over).
May 07, 2009 | Sharp FO 5700 Plain Paper Laser Fax
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Canon iR 2016i Black and White Copier Logo
91 people viewed this question
old marine
old marine
