Check in your owners manual, if you don't have the manual, take the bulb out and bring it with you. Usually it will take an appliance bulb. You can ask for this where you buy your bulbs
It's not a fan oven, so there's no moving parts.
It must be a panel or component (such as a shelf) vibrating in the heat.
When it's cold have a good look at the inside & see if there are any screw heads you can tighten & any of the components which can be pushed tighter.
Also check the thermostat probes to make sure that they're not vibrating against the side or top of the oven.?
Best of luck
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
If this information isnt help, this and other manuals could be find sending a request here.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Turn on the gas knob for the oven (below the grill) You will see an ignition button below the one that switches on the oven light,it is clearly marked. Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob. Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it Hope that helps [email protected]
