Question about Acer Computers & Internet
I have an Acer Aspire 7200 and my keyboard is fairly screwed up from spill damage. I was hoping to manually change it myself, but I don't know where to start taking parts apart. I have access to the memory compartment, but how do I access the keyboard from there?
    Guru:
  • 859 Answers
There are screws accessed from the bottom of your laptop, and in most cases labeled as keyboard, if not, start unscrewing these. Oh, as you begin to remove the keyboard and palm rest do not be too surprised if you hear large sounding snaps, this is normal. Once you begin lifting the top off carefully, you will see a thin mylar ribbon cable or two. You will want to download a users manual on servicing your internal components as there is a specific way to remove these ribbon cables. Usually you squeeze both ends of the female receptacle together and the cable will come loose. Same for reattaching it later. Once, you do have it off however, survey the internal area of your laptop for evidence of the spill and clean it up with 99% or pure alcohol from a hardware store (oh, and of course do this with external power disconnected and the battery out). Next, you may be able to salvage your keyboard by rinsing it down with electronic parts cleaner. It may take more than one can to do this, but you may find that this fixes your stuck keys and you do not have a need to replace it.
I'm hear to assist you further if you have any other questions just comment back and or click on the Ask Me icon.
Best Regards and Good Luck,
Worldvet
Posted on May 29, 2008
I spilled liquid on my Acer Aspire One netbook, and now some keys don't work on the keyboard. How do I fix this problem?
Below is the link to the service and repair guide. Change out the keyboard...they do not do well with spills. They are really just one big circuit board. Buy one cheap on Ebay and change it out following the guide below.
http://tim.id.au/laptops/acer/aspire%20one.pdf
Nov 25, 2009 | Acer NSK8458AN Keyboard
Acer Aspire One A0A150 keyboard issue,
Sounds to be you just got a faulty keyboard from HongKong, if your old keyboard works except the the Z and the new keyboard works only with function keys, then it sounds to be that the new keyboard is not ment for your laptop. if anything you should of had the same problems as your old keyboard. try using a USB keyboard.
Aug 17, 2009 | Acer Aspire One AOA150-1983 Notebook PC
How do I physically replace the keyboard on my Acer Aspire 5920?
If the keyboard is malfunctioning due to factory fault, you can request a warranty repair from Acer depending on the status of the warranty.
If keys have fallen off or if the damage was caused by a liquid spill, the warranty option doesn't apply.
If you already have the keyboard, you should be able to find repair documentation on Acer's site.
There should be several screws on the back of the laptop. A few of them might have an icon near them that indicates the purpose of the screw. If you see any icons that resemble a keyboard, you should take those screws out. Then you will be able to take the keyboard out and replace it. Remember to be gentle during this process as the motherboard will be temporarily exposed.
Aug 08, 2009 | Acer NSK8458AN Keyboard
Keyboard removal Acer aspire 8920g
To take the keys off, gently pull up on the top side of the keys until they snap off. Just push them down again and they'll snap back on.
Mar 21, 2009 | Acer Aspire 8920-6671 Notebook
Keypad spill on Acer Aspire 3613 Laptop
More than likely the pop has gotten inside your unit. you would have to open the unit, disconnect your keyboard, clean the leads and connectors to the keyboard. If the unit was on when this happened the mb may have shorted in which you would need a new kb.
Dec 06, 2008 | Computers & Internet
Spilled pop on laptop Acer Aspire
well.. i dont think that this keyboard will ever work...
You need to replace the keyboard..... and for this you may need to contact any technical person.
regards,
Dec 06, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 9300 Keyboard replacement
I have the Acer 9000/7000 pdf service manual if anyone would like it.
You may contact me at jonyjams @ hotmail.com (take the spaces out before and after the @ sign)
Dec 04, 2008 | Acer Aspire 9300 Notebook
Total keyboard stopped working
Try to format the machine and reinstall the operating system
Jul 31, 2008 | Acer Aspire 5315 Notebook
How do I remove the keyboard on my Acer Aspire 1640z?
Ok,
Usually there are hidden screws under the screen.
usualy under some clip or something.
if you find them unscrew the keyboard.
DO NOT YANK IT OUT!
carefully remove the cord .
PLEASE SEND A PHOTO OF THE LAPTOP for further info
Jun 30, 2008 | Acer Aspire 1640Z Notebook
Acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Jan 03, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
