Question about Garden
Where do I plug in my charger on my MTD electric start lawnmower? I have the charger but I'm foxed to where the connector is on the mower.
  • 2,100 Answers
It connects directly to the battery terminals with the alligator clips on the ends of the charger. Red to pos and black to neg. If the battery is low, it will take all night to charge up. I hope your not thinking it needs to be plugged in to start every time. If it doesn't start, do you have it in gear? Mower blades engaged? Clutch in? Sitting in seat? All of these have safety switches on them and it won't start unless they are all in the right position. Like off. Check it out.
Posted on Oct 07, 2010
Lawnflite 630 ride on mower. Key to turn how do we start the engine?
hi,
did you lose your key? here is a link to buy one, they are generic so you might be able to go to a local lawnmower shop for that. if it wont start with the key check your safety switches at the blade control lever under the panel and under the seat. riding lawnmowers that sit out get rusted all over, look for rust and bad connections under the service panel and battery compartment, sand connections with sandpaper..
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/136-630-331-lawnflite-lawn-tractor-1986-forest-city/electrical-without-headlights
Jul 31, 2017 | Garden
Hi, my question is how to connect the battery charger of the MTD mini rider 76E.Thank you.
You should be able to connect the charger directly to the battery and plug the charger in to an outlet. Black to negative, Red to positive...
Apr 12, 2015 | Mtd Garden
2008 mtd lawnmower tries to start when sprayed with carb cleaner but stops after 3 seconds
If the spark plug is in great condition, remove and clean the carburetor. This will require soaking if needed with a good solvent or carb cleaner and compressed air to blow out the tiny passages that are clogged for the idle jet circuit and high speed circuit.
Apr 29, 2011 | Mtd 22" Yard Machine Push Mower
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Lawnmower
what do you mean doesn't engage? doesn't start, doesn't let you pull, doesn't cycle, what?
Jun 08, 2009 | Mtd 22" Yard Machine Push Mower
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
