Question about Acer Aspire 55345410 Notebook
Battery won't charge works with adaptar - Acer Aspire 55345410 Notebook
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 07, 2010
Panasonic KX-TG6700 Phone
test the adaptar if working try it in another phone
2) sure the the line cord is plugged firmly in the phone base
3) unplugged the phone base . Wait from 30 seconds, and plug it again. Allow up to one minute for the cordless handset and phone base to synchronize.
4) charge the batteries by 16 hours aprox.
5) if the batteries is completely dead can take 30 minutes before low battery appears on the screen.if doestnot work replace battery by new ones.
try agan.
Oct 03, 2012 | Panasonic KX-TG6700 Phone
The battery doesn't work fine
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 26, 2012 | Motorola Mobility RAZR V3
Laptopwont work at battery only in mains
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 12, 2012 | Computers & Internet
I reinstalled XP on IBM T41, now battery won't charge. Could this be Driver Problem
Sounds like you need a new battery.
It's not just a battery in a case, it also has a small circuit board inside to control the charging etc, if that's faulty it won't charge, or if it has dead cells in it won't charge.
Feb 08, 2012 | IBM ThinkPad T41 Notebook
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Diescribe your Pavilion dv7-1245dx PC Notebook. just recently i purchased a new battery and i returned it because it was not charging correctly so i got another one and i,m still having the same problem, i...
It is normal for the adapter to run warm, but it shouldn't feel so hot you can't touch it. Since you have tried a couple of replacement batteries and still have the same trouble, it's safe to assume that either your adapter is bad or that there's something wrong on the computer system board. New adapters are easy to find and not very expensive (here's one seller on eBay), so that would be the next thing to try.
If the motherboard is the trouble (something wrong with the charging circuit), that's replaceable as well but it's not a cheap or simple repair. A replacement board may cost $100 to $200 for a used and tested part, and over $300 for a new one from an HP-authorized part seller, and installing the replacement can be very tedious. It might be more economical to replace the computer if the motherboard is bad. Try a new charger first.
Sep 11, 2011 | HP Pavilion dv7-1245dx Notebook
It worked for a while and I was able to recharge it, but now it won't hold a charge.
Sep 01, 2011 | Cell Phones
I have a dv6500 and it work only whit te battery. the ac adapter dont charg the battery and the pc dont work and the charger its ok. maybe a fuse?? tks rgds
Aug 19, 2011 | HP Pavilion dv6000z Notebook
Lenovo x 60 tablet battery shows 0% available , not charging. its a new battery i bought.
If the laptop works fine while plugged in but stops working while unplugged, It's likely that either your laptop battery is broken or your laptop battery is not charging properly. Below steps can help you identify the cause of this kinda problem
1. Leave Power plug in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
2. Remove and Reinsert Battery
In some situations the battery can become loose. Removing it and then put it back into the laptop.
3. There is Some Software
Use battery utility to determine the total capacity of the battery. For example, Battery Care Software is a free software utility capable of doing this.
4. Refreshing Battery
Some laptop manufacturers allow for batteries to be refreshed through the CMOS setup.
If problem still there. try Replacing Battery or Power Adaptar.
still the problem persist take the laptop to Service Center
best of luck..
Jan 29, 2011 | IBM Lenovo ThinkPad X60 Motherboard -...
Kodak m883 will not charge.
Hey Kovue,
If you just got this camera and the battery won't charge right out of the box you have a few options. You could have the battery replaced by Kodak, and the battery model # is
KLIC-7006. You are most likely within your return/ exchange period, and you could just bring the camera back to the retailer and exchange it for a new one. Unfortunately with the number of camera's the manufacturer makes they do sometimes produce a defective product. Your camera not charging could be due to a bad battery, or it could be due to a problem in the camera.
Sincerely,
Allan
Go Ahead. Use Us.
May 08, 2008 | Cameras
Acer Aspire 55345410 Notebook Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
