Question about RCA HD52W59 HDTV Projection Television
Colors present but look like they are out of alignment
  • RCA Master
  • 8,617 Answers
Thats a convergence issue. You can get the convergence repair kit for that model at www.tvrepairworld.com the kits also contain the CD with instructions.
Posted on Oct 07, 2010
How do I align heads on my Canon MG2200
Step 1 Ensure the printer and computer are turned on and connected.
Step 2 Locate the printer utility program by clicking on the printer's desktop icon if present. If it is not, click Start and type the printer make or model into the search box. When the printer utility program is displayed, click the program name to open the utility dialog box.
Step 3 Locate the "Maintenance" tab at the top of the printer dialog box and click to view contents. If the tab cannot be found, the maintenance screen can be accessed by clicking on various buttons (Advanced, Tools or Properties) and subsequently searching the dialog boxes to locate the maintenance button or tab.
Step 4 Click "Align Print Heads" or a similarly-phrased button.
Step 5 Click "Print Alignment Page" to yield a test page printed with a numbered series of vertical bars in various colors. Click "OK" or "Finished" to open the next instructional dialog box.
Step 6 Inspect the page, choosing bars from each color group with the sharpest image, and enter the corresponding numbers into the text fields for each color. Click "OK" or "Finished" to begin the automated alignment procedure. The printer adjusts cartridges based on the numbers you've entered. When the process is completed, you may click "Finish" to close the window and process, or print a test page featuring detailed shapes and lines of varying colors to further inspect. Click "Finish" to exit or "Repeat Alignment" to further adjust cartridges.
Jan 31, 2015 | Canon Office Equipment & Supplies
After installing the new catridge, i can not align the catridge. i don'tknow why.. please help me.
- power the printer off and disconnect it from the computer
- power the printer back on
- run an alignment page (make sure that all the colors are present and look good. If all the colors are not present or are poor quality, it may not work until you replace those colors.)
- place alignment page into scanner and scan. Make sure to place the top of the page (leading edge as it came out of the printer) into the scanner first and that it's facing the correct way.
- if that still didn't correct the problem, try flipping the paper to the other side and try again.
Hopefully that should work and you can hook the printer back up to the computer.
Jun 24, 2011 | HP J3680 Officejet All In One Printer
I am getting message that ink cartridge alignement problem
Make sure the cartridges have ink in them and they are funtioning correctly.
Take the cartridges out of the machine and do a dap test of both cartridges on
some tissue paper. Make sure all colors are present on the tissue paper.
The printer requires all the colors to be operational to complete an alignment
Feb 16, 2011 | HP Officejet 4355 All-In-One InkJet...
HP 4650dn printer, two problems: 1) color streaks on the print out 2) black color a bit gray, and turn a a bit white when superimposed on other colors (except yellow)
Please use the Print Quality Troubleshooting Tool for your printer's model at the following link:
http://h10039.www1.hp.com/cpso-support-new/pq/4650/home.html
This will take you through a step-by-step process to diagnose the cause of the problems you have & correct them.
Feel free to let me know if you need any further assistance.
Dec 17, 2010 | HP LaserJet 4650 Color Printer
The red and green projections aren't aligned. how can i align them?
You didn't say what make or model TV but generally the green CRT bulb in projection TVs is stationary and the red and blue adjust to the green. If you have all three colors present and you cannot get them to align Then you have a problem with the convergence circuit of the TV. If you post a comment here with your make, model, and chassis numbers (on the label on the back of most TVs) I can further advise you.
Dec 06, 2009 | Televison & Video
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
HDP600 print ribbon will not align properly. Using the diagnostics section, the color ribbon, ymckk, will not align to its correct starting point so that an accurate id card can be produced. The data is...
If card image is spread out into the yellow panel and the next magenta panel ...and so on skiping panel of the ribbon, then is defenitlly a sensor mis calibration problem. Check if you working in a place where to much natural light is present. The printer needs to detect the diffrent colors of the ribbon panels to print without skkiping them. re-calibrate the sensor. also as to "see or sense" the timing white marks on the ribbon that separates each panel.
I hope i help
ventas@intesys.org
Feb 25, 2009 | Fargo HDP600 Thermal Printer
JVC HDTV Pictrure Distortion
Your TV needs to be calibrated. Rear projection TVs are very sensitive to movement. They have 3 color canons that need to be precisely aligned so that the colors overlay each other. They are like three projectors all aimed at the same screen.
If you were to enter the User Menu on the TV, you should find an alignment/calibration choice that will re-align the colors using some on-screen help.
If you are not able to resolve the situation on your own, a certified ISF Calibrationist should be called.
And, since you've bought this TV used, it should be cleaned by a professional (the canons, lenses, etc.)
Apr 07, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Cartridge jam
Dear Satz This problem shows when dust has come in your printer. If you have a dust cleaner pump, you should try to pump air in your printer. And About align cartridge, "Installed cartridge again (color and black) after removing. Printer print a test print, that is called alingnment page, Take this alignment page and put it into the scanner, printing area should be on mirror side. and press scan button, which is present in keypad of printer (last one) you will hear the voice of scanning after 45 sec. light will stop blinking and still. It means cartridge have been aligned.
Apr 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
RCA HD52W59 HDTV Projection Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
