Question about Equator EZ 1500 Front Load Washer / Dryer
My Servis Caress 1500 seems to be washing the clothes ok, but does not appear to be effective at the spinning stage, with the result that clothes come out of a wash still completely wet. We are having to wring the clothes out manually. This is still the case even if I just put the wash on a fast spin cycle. What is the problem? Please help!
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
  • 105 Answers
SOURCE: Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Posted on Feb 02, 2008
SOURCE: EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Posted on Apr 05, 2008
  • 3 Answers
SOURCE: Dryer not working properly
its likely to be the condenser unit in the rear of the machine full with lint check for a large clear / opaque unit with pipes connected and make sure it is clear
Posted on Jun 19, 2008
SOURCE: I have an equator washer/dryer
I have one of these things, too, an EZ 3612 CEE. I've replaced the pump on mine, but I am in no way an appliance technician. However, your problem seems like an electronics problem to me and the service people I've spoke to about this machine have told me that the main circuit boards in these machines fail regularly. That has yet to happen to me. I would suggest calling the equator service number. You'll be connected to some technician in India, almost certainly. But my experience with these guys has been great. They have VERY patiently talked me through a couple of different diagnostic procedures and solved some problems. Don't have the phone # just now but you can google equator appliance and get it.
Posted on Jul 23, 2008
My Servis M3001 washing machine will not fast spin , it will spin and the belt seems to be ok , the machine is filling and draining ok , can you help at allThank you
Some times on front loaders if it is out of balance it will not go into fast spin. Try to remove some of the cloths and see if this helps.
Best of luck
'RR
May 15, 2014 | Washing Machines
Washing Machine does not start
It could also be your line to the machine is fried at the ends where the electrical hook up is. Look at the connections on the back of the machine. One may be fried
Feb 21, 2014 | Washing Machines
Servis 7kg 1500 AA - bush's and motor, ok and
relay is stacked so you start the machine off position power on the wash butten you will check this method
Sep 13, 2011 | Washing Machines
Servis Caress 1500 A - seemed problem wet cothes Tested on prog14 slow spin water just trickles in from back but no spin Similar on other spin cycles
I'm sorry but your posting is a little confusing to me. If I understand you correctly the water is just trickling in? Water shouldn't run in on any spin program as spinning is to get rid of the water out of the clothes. Water should only feed in during the pre-wash, wash and rinse cycles and be removed after each of those by the drain motor ;-0)
So- I will address a poor water filling problem in the hope that that is what your washer is suffering from- (if it isn't please 'reply' back to this posting, Thanks!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 12, 2011 | Washing Machines
Manual instruction for servis caress 1200 a
i want to connect a hot water to my caress1000`a`
is it possible?and how our washing machine could control the temperature.(washing machine has a cold water connection)
Aug 31, 2010 | Washing Machines
Can I get a a circuit diagram for a Servis caress 900 washing Mac
Their is usually a wireing scmetac inside the timer and switch housing of most machines.
Aug 25, 2009 | Washing Machines
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Have a Servis 1500 Easilogic washing machine. Decided last night that it won't do the spin cycle. Any ideas? Many thanks! Peter.
i used to deliver servis machines and exchange faulty ones, the most common problem was the regulator (the wash selection dial) they are not very sturdy and frequently break down. have you tried just a spin, without a wash.
Jul 01, 2008 | Washing Machines
Servis washing machine
the bushes might look ok but they only last a year and a half tops thats wat it sounds like to me if it cant spin right
Mar 03, 2008 | Kenmore 22422 Top Load Washer
Equator EZ 1500 Front Load Washer / Dryer Logo
205 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
