Question about Western Digital HARDDRIVES Hard Drive
My friend install my windows and changed my harddrive now i have 2 hard drive (dual) how to change it to one again
  • 2,574 Answers
You need to format your driver.and install windows.this is the only solution i can get u
Posted on Oct 07, 2010
  • 787 Answers
Those are partitions, you don't have two hard drives. And it's better this way. For example, if Windows crashes, you won't lose the entire contents of your laptop. If you put your music/movies/pictures to the other partition they will be safe.
Testimonial: "i never taught of it that way, thank you"
Dual boot xp with windows 8
No solution now, Install Windows XP again on first partition, Make sure BOOT.INI, NTLDR, NTDETECT.COM in the same partition in which Windows XP is loaded. Then install WIndows 8.
OR in the current scenario you've to do much technical work using third-party tools.
Feb 27, 2014 | Microsoft Windows XP Professional With...
L350 170 toshiba can it support 2 harddrives
Both. Install from Windows and choose drive. It will create a partition on drive chosen. Plus you can choose size partition during setup.
Aug 29, 2012 | Toshiba Satellite Pro L350-S1001V...
Screen turns on while booting, after a minute or 2, goes blank.
Sounds like windows is hanging up or the hard drive is bad. Try to reinstall windows. If you have files you want to save;
(1) you can install windows on a new hard drive
(2) install windows on a different part of the hard drive. (You'll be asked by windows where you wanna install)
(3) remove the hard drive and copy files to your/a friends PC.
If the windows disk is in the CD/DVD drive and still get a black screen then your hard drive is bad.
Aug 11, 2012 | Toshiba Computers & Internet
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
Replaced harddrive and dvdroom wont recognize in bios
Goto bios menu. And change the setting on hard drive and cdrom. It could be it still set in the old configuration. Try to set it in auto detect. Then save the setting. Then goto bios once again to check if the settings doesn't change. Restart again and wait if something you didn't expect still happens.
Leave a comment if this solve cd rom detection.
May 12, 2009 | Gateway M-6750 Notebook
Fujitsu Siemens AMILO D1845 keeps freezing
have you tried a fresh install of xp I do not understand?
Oct 24, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
C000221
change the operating system cd try again change ur ram with any other ram from ur friends and try thats it ur probelm gets solevd in one of the cases try them gud luck
Apr 16, 2008 | Microsoft Windows XP Professional With...
Bad Harddrive
please check your cables and try with new one.check the bios setting
Apr 04, 2008 | HP Compaq Business Notebook NX9010
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
Help me ! Lacie ED Disk Ethernet 10/100
if you are using (sata)harddrive dont install windows 98.i have a solution now before connecting your harddrive change the jumper to the slave (for single harddrive and single cd-rom or combo drive).it will work.plz install windows xp (service pack 2) or windows vista these are good versions for all!
Dec 07, 2007 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
49 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
