Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Replacing Lamp I have a replacement lamp and the side rear covers are removed from the set. I can't get the panel to come off. It seems to be attached in the middle near the on/off switch. I don't want to force it because I don't want to break the plastic panel. Any tricks involved or should I give up and call a technician? Any help would be appreciated. Curt
You're supposed to loosen the 2 big plastic looking screws on the bottom back of the screen. there should be one on the bottom right & bottom left. the ones on my tv were easily taken off with my hands. after you do that, go to the front of the tv. take off the bottom plastic piece below the tv screen. it's stuck on with a big magnet. tug @ it.
Posted on Jun 04, 2008
Changing backup bulbs on 2005 buick rendevous
TAIL LAMP ASSEMBLY AND /OR BACKUP, SIDEMARKER, STOP, TURN SIGNAL BULB REPLACEMENT
REMOVAL PROCEDURE
1. Open the liftgate.
2. Remove the screws from the tail amp.
3. Slide the tail lamp rearward in order to disengage it from the retainers on the rear body panel.
4. Disconnect the electrical connector from the tail lamp wiring harness.
5. Remove the tail lamp and side marker lamp sockets from the tail lamp, depressing the locking tab and turning counterclockwise.
6. Remove the bulbs from the tail lamp and the side marker lamp sockets, if replacing the bulbs.
INSTALLATION PROCEDURE
1. Install the bulbs to the tail lamp and side marker lamp sockets, if removed.
2. Install the tail lamp and side marker lamp sockets to the tail lamp, turning clockwise until the locking tab is fully seated.
3. Connect the tail lamp electrical connector to the wiring harness.
4. Position the tail lamp retainer slots to the tabs on the rear body panel.
5. Install the tail lamp to the rear body panel, pressing into place until fully seated.
6. Install the tail lamp screws to the Taillamp.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the tail lamp screws to 2 N.m (18 lb in).
7. Close the liftgate.
Apr 16, 2017 | Buick Cars & Trucks
Can you give me instructions on replacing the interior light on a GE Monogram Advantium 120 Micro Wave Oven. thank You
I have not worked on this model:
Normally the way to change the light is to remove the interior access panel OR ... (if no access panel) remove the oven cover to get access to the lamp. Two screws on each side and 6 or 8 on the back side. Lift and tilt and slid the cover from the front interlock seam and set it aside. DON'T TOUCH the silver can you see on the side. Find the lamp, remove and replace and put the cover back on.
Allow 15 minutes to do this job. Get a replacement lamp where appliance parts are sold.
Thanks for your question
Feb 03, 2011 | Microwave Ovens
Do I remove the entire cover or the little door thats atached to this cover on the passenger side? There are 3 brake lights that were recommended to replace. Driver side and passenger side plus the third...
Lamp, Rear Hi-Mount Lamp Assembly
Removal
  1. Disconnect the battery ground cable (14301) .
  1. Raise the liftgate.
  1. Remove the liftgate door trim panel (46404) . Refer to Section 01-05 for the removal procedure.
Trim Panel, Liftgate Door Removal
  1. Disconnect thebattery ground cable (14301) .
  1. On vehicles with a rear window wiper, remove the three rear wiper motor cover screws and remove the rear wiper motor cover.
  1. Pry the liftgate door trim panel (46404) away from the liftgate.
  1. Disconnect the luggage compartment lamp electrical connector.
  1. Rotate the rear hi-mount lamp socket counterclockwise and remove it from the rear hi-mount lamp (13A613) .
  1. Remove the two rear hi-mount lamp housing nuts and remove the rear hi-mount lamp lens and housing.
Oct 18, 2010 | 1995 Ford Aspire
What do I need to unscrew in the trunk to change the reverse light in my 01 chevy impala
Tail Lamp Assembly Removal & Installation To Remove:
  1. Open the rear compartment.
  2. If equipped, disconnect the cargo net.
  3. Remove the wingnut and pull back the rear compartment trim panel.
  4. Remove the wingnuts from the tail lamp assembly.
  5. Remove the tail lamp assembly from the rear body panel.
  6. Disconnect the electrical connector from the tail lamp assembly.
  7. Remove the tail lamp socket by turning counterclockwise.
  8. Remove the side marker lamp socket by turning counterclockwise.
To Install:
  1. Install the side marker lamp socket by turning clockwise.
  2. Install the tail lamp socket by turning clockwise.
  3. Connect the electrical connector to the tail lamp assembly.
  4. Position the tail lamp assembly to the rear body panel.
  5. Install and secure the wingnuts that attach the tail lamp assembly to the body panel.
  6. Position the rear trim panel to the rear compartment. Install and secure the wingnut.
  7. If equipped, connect the cargo net.
  8. Close the rear compartment.
Oct 18, 2010 | 2001 Chevrolet Impala
Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
GOODLUCK
Jul 04, 2010 | Akai PT61DL34 Television
The unit turns on and works perfectly for 5-10 minutes then the screen goes black and the sound turns off. I removed the back panel, blew off the dust, and checked the fan. The problem still persists. Sony...
Howdy,
It sounds like your Lamp is bad, part number XL2100.
To replace Lamp:
1) Loosen the screws on rear panel (2 thumb type screws on either side of TV, just behind front panel/spreaker grill).
2) Remove front panel.
3) Loosen the screw with coin or similar object to remove Lamp cover (near left hand side).
4) Loosen the 2 screws that hold the Lamp, then pull out Lamp. Don't force Lamp it should go in easy.
5) Replace the new Lamp and tighten the screws, reattach Lamp cover & tighten screws.
6) Reattach front panel cover.
7) Tighten screws for front panel cover in it's place.
Good Luck, Big Irish.
Dec 02, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Where is the bulb
The lamp is behind the frontspeaker grille, on the left side.
Dec 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Whow to replace lamp on tv sony kdf-e60a20
Follow this procedure to replace the lamp:
1. Turn off the power on the main unit. Wait several minutes, then unplug
the power cord.
(The cooling fan will continue to operate for about two minutes after
turning the power off.)
2. Wait at least 30 minutes after unplugging the power cord to allow the
lamp to cool down before replacing it. To avoid being burned, do not
touch the lamp receptacle once the lamp has been removed.
3. Take the new lamp out of the box.
Do not touch the glass portion of the new lamp.
✍ Do not shake the lamp. Vibration can damage the lamp or shorten
its life.
✍ Avoid touching the front glass of a new lamp or the glass of the
lamp receptacle. This may reduce picture quality or lamp life.
4. Loosen the screws on the rear side panel.
5. Remove the front panel.
6. Pull out the lamp.
Loosen the right screw on the cover with a coin or similar object.
Remove the screw from the lamp cover. Pull down the cover toward you.
Unscrew the lamp and pull out the lamp horizontally.
✍ The lamp is very hot immediately after use. Never touch the glass
portion of the lamp or the surrounding parts.
✍ After it has cooled, place the used lamp into the empty box of the
replacement lamp. Never put the used lamp into a plastic bag.
7. Place the new lamp into its place, then tighten the screw.
Mount the new lamp securely. Failure to mount correctly may cause a
fire or the screen to go dark.
Push the cover back on. Make sure that the hole on the cover aligns with
the hole on the unit. Reattach the lamp cover by tightening the screw.
✍ If the lamp cover screw is inserted incorrectly, the lamp may not
operate properly. In such a case, remove the screw, insert it
correctly and then tighten the screw completely
✍ If the lamp cover is not reattached securely, the self-diagnostic
function may be triggered and the POWER indicator flashes three
times
8. Reattach the front panel securely.
9. Tightly screw the side panel in its place.
That is it. Thank you.
Nov 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Replacing lamp for a sony lcd Kdf50WE655
it is located in the front of the set behind either a long metal strip cover or a plastic cover. some sets have wing nuts hoding the cover in place. they would be located on the left and right hand side of the set near the bottom edges.
Jan 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Zenith E44W46LCD Lamp Access Door Location
I found the location to get at the lamp. If you are loking at the front of the TV there is a small panel at the bottom of the right end. Two screws, remove panel, two screws inside and a small handle that lifts so you can slide the unit out. 4 screws on top of the cage that the lamp sits in, carefully slide up the silver bracket holding the bulb, be careful the edges are sharp. Remove the bulb from bracket and remove the 2 cables attached to the bulb. Now just do the same but in reverse. Make sure you wear plastic gloves that should be provided because if your fingers touch the lense you could be out the price of the lamp.
Aug 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
