Question about Canon Speedlite 550EX TTL Flash
Flash 550 lcd screen lighs up but will not fire the flash
My speedlite flash 550 lcd screen lighs up but will not fire the flash.
Have been in touch with Canon on the phone and they said it could be a circuit and to replace approx $300 which to me seems a bit excessive. Should I just buy a new one?
  • 22 Answers
$300. ? To REPAIR? Way out of line. Replace the unit with a similar flash or go for another brand. SUNPACK flash units are reasonably priced and the have models that work with Canon abd orher cameras.
Ed
Posted on May 29, 2008
Speedlite 580 pilot light on but flash wont fire
More info needed: Will the flash fire when you push the test button? Have you rest the camera you're using to factory defaults while the flash is mounted on the camera and turned on?
Jan 06, 2014 | Canon Speedlite 580EX II TTL Flash
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
Speedlite 430EXII Flash not working. Batteries OK Everything functioning except that it's not firing. Took 3 pics yesterday and then it stopped working. Regards Alan Paramor
Does it fire when you push the test button (red light)? If so make sure the contacts on the lens and on your camera are clean. My speedlites sometimes don't fire after heavy use and I clean the contacts with a soft cloth and some methylated spirits or isopropyl alcohol. Hope this works for you.
Jan 21, 2011 | Canon Speedlite 430EX TTL Flash
Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Nov 03, 2009 | Canon Speedlite 430EX TTL Flash
The flash won't fire, and the pilot light won't come on. I've tried new batteries, and that doesn't work. The little LCD screen does have power. I'm wondering if I blew the strobe. Thanks!
Hey i have a 430ex mk1 which when turned on did not fire and red pilot light did not show , i have had the flash since 2006,
i have also tired new batterys and the LCD Light works and the Txt shows up,
did you work out the problem and also how to fix it?
thanks
rick
email
psnp@hotmail.co.uk
Oct 05, 2009 | Canon Speedlite 430EX TTL Flash
Canon flash speedlite 550 ex ttl
Send the flash back to canon for Service this is not something that can be fixed in this forum. Do not use the flash the burning smell indicated a potentially dangerous problem and fire hazard.
Jan 09, 2009 | Canon Speedlite 420EX TTL Flash
Remote Firing of Flash Units
The EOS 40D does not have a transmitter built in. The remote flash units must be set to "Slave" and the on-camera external flash unit (eg Speedlite 580EX) or transmitter (ST-E2) set to "Master". Note that the Speedlite 430EX doesn't have the function to act as Master and you need a minimum or the 580EX or a ST-E2 speedlite transmitter (or similar) as Master/s.
Jul 29, 2008 | Canon EOS 40D Digital Camera
Won't Work As Slave With Canon EOS 400D
Speedlites with the suffix "EZ" are never compatible with the digital EOS line-up. All models that do work are named "EX" (420, 430, 550, 580EX et al.)
Apr 03, 2008 | Canon Speedlite 540EZ TTL Flash
Flash quit flashing
To test the flash to fire without the camera:
Cut a wire about 4" long.
Strip both ends to about 1/4" to exposed the wire.
Turn on flash, wait until fully charged.
Touch one end of wire(lead) to Center of flash contact and hold in place.
Touch other end(lead) to side of flash.
This should fire the flash, if the tube or the cap is good.
Hope they are helpful.
Alexander
atdlee@netzero.com
Dec 09, 2007 | Canon SPEEDLITE 580EX TTL Flash
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 550EX TTL Flash Logo
223 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
