Question about Karcher 2500 PSI Pressure Washer
Honda gc160 engine on 2500 psi washer, no spark?
I have been using my washer on a weekly bases, but it only has 10-12 hrs. on it. I used it today for about 5 min. and then it stopped running. I checked oil it was ok, checked the gas tank and there was 1/4-1/3 of a tank, pulled the plug to check for spark and no spark. Can you give some troubleshooting help. THANKS
  • 13,433 Answers
No spark from the plug? you have to change the plug.
Posted on Jun 05, 2008
    Master:
  • 555 Answers
New spark plug? flooding may have fouled the old one.
Troy-Bilt 2500 psi / Honda GC160. 5.0 hp. No manual. What weight oil? Straight gas or also mixed with oil?
Hello, I have found this for you. The first link is to the engine manual page and, The second is to an owners manual that may be what you need.
hope this helps. :)
http://engines.honda.com/parts-and-support/owners-manuals/gc160
www.e-barnett.com/ProductDocument/10148/2490717_Owners.pdf
Aug 08, 2016 | Honda Garden
QUE TIPO DE ACEITE USA LA KARCHER GC160
tengo una maquina honda gc160 5.5
modelo g2600 vh con seria 152 428
Jun 29, 2011 | Karcher 2500 PSI Pressure Washer
What type of oil is needed for a Honda GC160 Power Washer? Honda 2500 PSI x 2.3 GPM.
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
May 27, 2010 | Honda Pressure Washer PSI 3000
Pressure washer with Honda Engine GC160 only run with choke fully closed.
The carb is clogged. It needs to be cleaned, or replace. Keep in mind some of the carb passageways are as small as a human hair so they are difficult to clean which is why I mention replacing. You can try using carb cleaner etc in the gas, but I don't think it will work if you need the choke that much.
Apr 29, 2010 | Karcher 2500 PSI Pressure Washer
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Runs fine gc160 wont give me any pressure. i took the pump apart and cleaned it then put it all back together the pressure was intermediate but now nothing at all
if you give us a bit more information we may be able to assist!
is it a pressure washer you are trying to get running.
the number you give is the model number of the honda engine. 5.5 hp honda domestic use.
what does the pump look like. etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Honda 5hp engine wont run
check oil level. it has a low level shut off switch ?? May be it
May 04, 2009 | Karcher 2500 PSI Pressure Washer
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
949 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
