Question about Minolta Di2510 All-In-One Laser Printer
Cobao - Minolta Di2510 All-In-One Laser Printer
  • 1,110 Answers
90% of the time when I see this code it means that one or more of the trays on your finisher are not installed all the way into the finisher. Look on the far left side of the machine where the trays are that catch the papers as they come out. Make sure these trays are fully into the slots they sit in. There are little switches that are actuated by the trays as the elevator goes up and down. If the tray misses a switch it will throw the COBAO code. Basically the code means elevator motor lift or descent failure. Turn the machines main power switch off then back on to reset and see if the code goes away. You should see the finisher go up and down. If it never moves then you have a problem with the elevator motor or the detection system. But most all of the time it is just one of the trays not sitting fully into it's slot.
Thank You for using Fixya.
We are having a contest this month based on customer testimonials. If I have helped you with your free question today please leave me a testimonial.
Thanks!
Posted on Oct 07, 2010
Bizhub 2510earer coad cobao
The FN finisher unit elevator motor malfunction.Remove the finisher unit and work with out.
Jul 22, 2014 | Konica Minolta Clutch for Di3510 3010 2510...
How to fix a cobao error on a DI3510f multifunction printer
COBAO - Elevator motor ascent/descent drive failure.Remove the finisher unit and work without.
Jul 08, 2014 | Minolta Di3510f Bizhub Copier
Minolta code cobao
Check the stapler in side the machine.
Jan 13, 2014 | Minolta EP4000/5000 CS/PRO Copier
Dialta di 2510 has code COBAO
Did someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the trays has to just touch them.
Nov 14, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
COBAO error on NEC IT3520/KM Dialta 2010
Sir,
Was there a trash can or box of paper underneath the finisher part that moves up down. the code is failure of the up and down motor for the finisher. Normal happens when the trays that move down they hit something. or the mootr has failed. Open/close the door to the finisher, power off both power switches including the one on the rear left side and the one on the front panel. wait ten seconds then turn them on again. Also check to make sure there is not something binding the tray system
Jul 02, 2009 | Konica Minolta DiALTA Di200 Copier
Konica di3510 there is a code on the screen cobao
Elevation drive motor failure for the finisher /service manual
May 05, 2009 | Konica Minolta DiALTA Di200 Copier
Bizhub c350 -cobao code
finisher elevator drive error. Check the finisher tray for blockage or something under the tray. If all else fails, unplug and disconnect the finisher
Jan 20, 2009 | Office Equipment & Supplies
Minolta copier Di3510 error code cobao
Output tray elevation motor is bad or there something stopping it from lowering or raising.
Aug 18, 2008 | Minolta Office Equipment & Supplies
Minolta Di2510 All-In-One Laser Printer Logo
260 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
