Question about Sony Cyber-shot DSC-N2 Digital Camera
The problem where I come when you run Access for 10 seconds then comes the following text turn power off and on again, but whatever you do stay the same defect or remove the battery switch off ..... What is the solution Please in the near future
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 15, 2011
Pattern reset
Press - 'Volume Button up + Scroll button + Power button' all at the same time. As soon as the phone starts, release the 'Power Button' but continue to press the other two buttons until you see the green Android logo. Then release the other buttons and wait until lines of text appear on the screen. Scroll down (using volume key) to the text line "wipe data/factory reset". Once highlighted press scroll button once and wait until phone is formatted. When the lines of text appear again, choose the top one which says "Reboot phone". Then follow whatever instructions that come on screen. Remember you need to update your Gmail/Google account before you can access applications on "PlayStore".
Oct 21, 2013 | Samsung GT-S5300 Galaxy Pocket
I forgot a password and i cant access a catalyst 2960 24-port 10/10
You can only reset password this way:
1.
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
2.Unplug the power cable.
3. Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch
4. Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green.
5. switch: flash_init
6. switch: load_helper
7. switch: dir flash:
8. switch: rename flash:config.text flash:config.old
Rename config.text to config.old. In that file the password is stored.
9. switch: boot
10. Enter "n" at the prompt to abort the initial configuration dialog
11. Type en to enable
12. Switch#rename flash:config.old flash:config.text
13. Switch#copy flash:config.text system:running-config
14. Overwrite the current passwords:
conf term
enable secret <new pass>
enable password <new pass>
line vty 0 15
password <new pass>
login
line con 0
password <new pass>
15. write memory
16. copy run start
Sep 25, 2013 | Cisco Catalyst Computers & Internet
EMachine e627 screen blank
I am assuming you have plugged the screen into a known working power source. You have pressed the 'on' button to turn the screen on and you have hooked up the screen to the back of the computer. What I need to know is if when you power up the computer if you see any text at all from the post AND if you see any lights on the front of the screen itself. (most all screens have lights on the front of them to tell you they are turned on, and most of the time the light is green). If the screen is on but is getting an orange or amber light that means something. Also if you see text or something on the screen initially but not in windows then it could be a resolution or driver issue.
Jul 07, 2010 | Acer Computers & Internet
HP LaserJet 2015 printer series - PCL XL ERROR is reported during printing
First Solution :
1. Disconnect the Power Cor from back of Printer ( while printer is has power )
2. Wait for 10 seconds
3. While holding Power Button, Connect the Power cord and release the power button
2nd Solution :
This issue can be fixed by enabling the following option in Printer Preferences . To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet 2015 PCL, and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Jun 18, 2010 | HP LaserJet P2015 Printer
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Trying to program a remote, but it doesn't work.  i followed the instructions turned the key from off to on 8 times and left it at on, but the locks did nothing. can you help?
WHAT FOLLOWS IS THE CORRECT PROCEDURE, REMEMBER YOU MUST COMPLETE THE 8 KEY CYCLES IN LESS THAN 10 SECONDS, IF YOU DO IT RIGHT THE POWER LOCKS WILL GO UP AND DOWN TO INDICATE IT IS READY FOR PROGRAMMING.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Jul 08, 2009 | 2002 Ford Taurus
No text on any menu screens
Update the firmware.
RCA M4208
Make sure the lock switch on the back is in the unlocked position. For the player to say "Loading," especially the first time you plug it into the computer, is normal - your computer is communicating with the player, installing drivers, and trying to load the Easy Rip Software. If it stays on loading past 10 minutes, however, something is not right. If you have selected to open the device automatically using Windows Media Player, you are headed for trouble, especially if you have more music and other files on your computer than the mp3 player can handle. If you have accidentally done this, disable auto-sync in Windows Media Player.
If you have checked the above, and you are still having problems, disconnect the mp3 player from the computer. Hold in the power button for 10 seconds or more to reset the mp3 player. Try plugging the mp3 player into the computer again. If it stays on loading for more than 10 minutes, unplug the mp3 player, go into the settings menu and change the mode from MSC to MTP or vice versa. If it still misbehaves when you replug the mp3 player into the computer, download the latest Easy Rip software from RCA's website and update your player's firmware - take note of the section they have on Windows Vista if you have Windows Vista. Good luck!
-Tha Mp3 Doctor
Dec 30, 2008 | RCA M4208 MP3 Player
Sony Cyber-shot  DSC-N2 Digital Camera Logo
23 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
