Question about Toshiba 27D46 27" TV
Toshiba 27D46 27" TV Problem
I'm having the same problem with my Toshiba.  What did the repair shop specify as the problem, and how much did it cost?  Thanks!
  • 1 more comment
  • annie07 Jun 26, 2008
    I have the Toshiba 27D46 also and the same problem, a big white horizontal line across the middle of the screen. Sometime the full picture comes back and sometimes not. Has anyone had this problem diagnosed? Know what's causing it? I understand from the manual the picture tube is warranted for two years. Any help out there? This is driving us crazy! Thanks.
  • Glenn.M Dec 06, 2008
    I also have a vertical problem Screen squished to about 1/4'. I have replaced ic401 and a few of the caps around the ic. After i replaced the ic the picture went back to normal for about 30secs then back to the same problem.Like I said before I replaced a few of the caps in the vertical section, I am thinking its a cap , But I do not know what one to look for. Also I went over all solder joints for cold solders and everything looks good. If somebody can pont me to the right caps or parts to look at PLEASE HELP!!
  • mdt28 Dec 22, 2008
    Hi Robotek,
    I am unfortunatelly another person that has the white horizontal line on my TV. It use to come and go while I was watching it but now it is constant. Even if I turn it off and on, it is still there. I read all of your reports on this problem. I have had the TV apart to try and look at the boards and soldier joints but I am not sure where I should exactly look. Do you have any advice on the location of the vertical soldier joints or possibly a picture or diagram of this. Thanks for your help and advice. Mike (mdt28@verizon.net) Have a safe and happy holiday season!
  • 1,512 Answers
Hi
It will not be the picture tube. Your set will have cracked solder joints in and about the vertical output stages. This is not a major repair, and will require re-soldering of that stage, and maybe a few capacitors replaced as a cursory repair as preventative maintenance. should cost between $50-80 depending on who you get to look at it. If you are quoted a price higher than this, I suggest ringing around repair guys in your area and be careful to explain exactly what you have described the fault as here.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 13, 2008
it should cost you from $50 for dry solder joints up to about$120 for a rebuild of the vertical stages.
Jul 11, 2008 | Toshiba 27D46 27" TV
My tv toshiba 43n9uxa has a red shadow to images and seems tilted on the edges with blue hue
Ur tv convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300-350 for parts and labors.
Apr 26, 2010 | Toshiba 42H81 42" Rear Projection...
Toshiba model 42H81 projection tv receiving blue and yellow shadows on screen.
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 06, 2010 | Toshiba 42H81 42" Rear Projection...
Where can I get the front screens for my tv?
If you have to replace the linticular screen the cost will be prohibitive. The outer Plexiglas can be purchased at a hardware store although it will not have the glare reduction as most of the big screens have but it will work. Your best bet is to contact a tv repair shop and ask them if they have any toshiba 50" sets they are parting out and ask them for the cost of the screen. That may be your most cost effective way. I know if we had a customer to ask we would sell them one at a resonable price, but unfortuinatly our shop does not have any toshiba sets junked out. We have several sony's though.
Sep 02, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 50A60 Projection TV - Black Screen
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
May 17, 2009 | Toshiba 50A60 50" Rear Projection...
Color wheel price for a Toshiba 52HMX85?
Hello jjoana,
My shop charges the labor fee of $60.00 per hour and fraction of an hour. So a 1 hour 1 min job is charged as 2 hours. This is just the cost of labor. $60.00 is an average I took from 10 sampling of TV repair shops when I was developing my pricing scheme . I hope this gives you an idea of the labor charges, There maybe other fees attached, or depending on the shop the cost could be higher or lower.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 04, 2009 | Toshiba 52HM95 52" HDTV Projection...
I have no sound
Hello baby ewie,
You may have an audio processor problem, I would suggest taking the TV to a qualified TV repair shop or having a technician come out to you to check the TV. If it is the audio processor it should not cost too much to repair.
I hope this helps,
Thank you,
Shuttle83
Apr 16, 2008 | Toshiba 43A10 43" Rear Projection...
Toshiba Rear Projection Issues
Common problem is called convergence mis-alignment.
A correct repair requires above average technical ability.
Prevent maintenance and correct parts will be needed.
Most repair shops charge about 400.00 for an incomplete job.
Check other Tosh "H" Line solutions already written.....T.
Nov 03, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 27D46 27" TV Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
