Question about Sharp AR-M237 Copier
Sharp AM410 model showing heater fuser error and machine not starting
Fuser temp. error
Posted on Oct 26, 2010
How are you i have a sharp copier am 410 it is showing me fuser temperature error..can you please assist me on this?
Posted on Sep 08, 2011
Provide the solution it
Posted on Feb 29, 2012
How to clear Temp error on sharp AM410 printer
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Jun 02, 2016 | Sharp Office Equipment & Supplies
My sharp copier AR-407 is showing error code H5-01
hi this means you have had jams in the fuser or problems with the fuser/heater. You must clear all paper jams and the code by entering the simulation. to do this in a steady rythem press the # then the * then the red C key then the star key again. so its hash star C star
this will enter the sims. now enter 16 on the keypad then select yes. the machine may restart if this fails try the same as above but type 14 instead of 16, also 14 if you can. If this fails your fuser has a problem and may need parts changing
Jan 07, 2015 | Sharp AR-405 Printer
Error H4 00
This problem occurs in the Sharp copiers. Therefore pls check the fuser lamp (heater lamp) To reset this error code I need the machine model no correctly.
Feb 10, 2014 | Toshiba Office Equipment & Supplies
When i power on, it shows H4. the copier is Ar5520 sharp copier
H4 error is heat roller low temperature, try pressing the "#" key then "Interrupt" key then "C" key then "Interrupt" key to get into simulation mode and enter 14 and press start the follow instructions on screen (should be press ok). This will reset the code and restart the machine. When the machine restarts if the error was a not mechanical the machine should go. If not you have one of two most likely problems; you need to reset the thermal cut-out on top of the fuser unit or the fuser lamp is blown.
Oct 18, 2010 | Sharp Office Equipment & Supplies
System error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
May 19, 2009 | Sharp AR-168S Copier
How to remove h5-01 error code on a sharp arm550n copier
This is either:
10 continuous POD1, POD2 or PPD2 JAM
OR
Other models this indicates too many fuser jams. The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on.
Jan 20, 2009 | Office Equipment & Supplies
H 4 error
If the Reset does not work, then you have a fuser error and your machine will need service.
H4 is a fuser heating error code.
Meaning the machine is not warming up because of a bad lamp, thermal fuse, thermostat, and or thermister.
Hope this helps.
Good luck.
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
Doesnt work
h4 - is a heater lamp error - fuser is not heating up - machine needs the fuser repaired before you can use it, it has probally got a blown heat lamp, could be thermister or thermal fuse but usally on these it isn't. If you a teco happy and 240v comfortable then remove fuser and check lamp and components for open circuit, if you do not know what you are dealing with then dont try.... call a tec, this area runs live 240v
now this is under AL-1641CS but you are saying also  Digi A161
so I'll give you both resets use at own risk do not put in any other number but 14, damage will result, but this code I doubt will help you untill original problem is fixed, oyur machine will reset but error again also.
CLEAR - EXPOSURE SELECT- CLEAR - EXPOSURE SELECT really fast like 2 secs, display should blank then 14 start
or Press: "Clear", "Interupt", "0", "Interupt", "14", "Start Key"
Oct 30, 2007 | Sharp AL-1641CS Laser Digital Copier
Sharp AR 5316
there might be some dirt on thermistor above the heater upper roller pls check and clean the fuser unit then use simulation 14 to reset the machine enter simulation by presssing #,interrupt,c,interrupt in sequence display is then off, then no. 14 then start key h2 disappears ok
Sep 04, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M237 Copier Logo
783 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
