Question about Panasonic Televison & Video
Is it possible to buy a replacment remote control for a Panasonic HDTV 1081 BBE?
  • 71 Answers
You can find many universal remotes, including Panasonic, here: http://www.electronix.com/remote-controls-c-9.html
Posted on Oct 07, 2010
Panasonic HDTV 10801 BBE TAU
Unplug it for a few seconds and
plug it back in if this doesn't
do it the call in a technician
may be HV or PWR Sply problem
Nov 29, 2007 | Panasonic CT-32HXC14 32" TV
I have a Panasonic HDTV 1080i TAU BBE projection TV,I can't get a remote to work with it.
Check first to see if remote works---most shops or Radio shack have a remote tester---point remote at it and push a button and tester will indicate if remote works----some digital cameras will also work for this.
If remote is good either a problem with the remote receiver on front of set or the remote circuit inside the set.
Mar 18, 2012 | Panasonic Televison & Video
What remote control goes with the rca truflat tv?
Hello
Just buy one RCA RCR 311B universal remote control. You will get all instrucions and setup codes along with it. The setup codes for this remote with RCA TV are.
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205
gopakumarg43_34.jpgThis is the picture of RCA RCR 311B.
Aug 30, 2011 | RCA TruFlat 27F520T 27" TV
I have panasonic hdtv 1080 bbe. when I turned it on this morning everything was double vision. I see the normal but everything has a red double. what can I do to correct this
As long as the set doesnt shut down and have a 3 flash error code then just replacing the two STK392-110 ICs should solve the issue. However the Low ohm resistors (six 2.2 ohm resistors ) should be checked and possibly replaced with the ICs. You can get the actual convergence repair kit for your model which contains the ICs, Heat sink paste, resistors and the CD with instructions from www.tvrepairworld.com
Aug 06, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Need to reset lamp hr. meter on panasonic pt50LC14 tv with out the remote
Unfortunately you might need the remote. Otherwise up is channel up down is channel down left is volume - and right is volume +. Enter is the input/source button. A new original remote can be purchased here http://www.replacementremotes.com/Panasonic/Buy-EUR7603ZB0-Remote-Control.html
Feb 08, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Hi!!! my Tv is a Panasonic HDTV 1080i BBE High definition this is not a flat screen, the problem that it has is that the screen is not working well it looks like bouble imagen, what can I do?
I have never heard anybody refer to their tv as looking like a "bubble image" in the 15 full-time years that I have been a television technician, but all I can assume, is that you have a convergence problem, and you will need to replace both convergence ic's, and possibly some resistors. Approx. cost to repair by proffesional would be around $300.oo.
Nov 02, 2010 | Televison & Video
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I need a code for my panasonic tv remote as i took the batterys out for 5mins now it wont work
Buy a new alkaline batteries and try to use with them , if this dont have any effect , in the original manual of the tv , are the code of the remote , and finally if you dont find the code in the manual , buy a universal remote control , to use it with the tv
Nov 07, 2009 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Televison & Video Logo
445 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
