Question about Microsoft Office Outlook 2003 for PC
My MS Outlook's MAPI32.DLL file is currupted or the wrong version. Pls give me solution for Access Outlook.
    Problem Solver:
  • 6 Answers
Try this command- click on start- select- "Run"- type "fixmapi.exe. Restart the outlook
Posted on Aug 17, 2013
  • 477 Answers
Hello
try rename mapi32.dll and msmapi32.dll to the .old extension and start outlook or access
if that doesnt work try
1. Delete the contents of the "C:\Program Files\CommonFiles\System\MSMAPI\1033" folder
2. Reboot into normal mode and start Outlook/access, setup will replace the files
with the correct version and Outlok will load as normal.
Posted on Oct 07, 2010
  • tech2rw Aug 17, 2013
Is it possible to access Outlook Express emails from MS Outlook?
Use this DBX to PST Converter software to convert dbx to pst files in easy steps.This tool allows users to convert the multiple DBX formats with their respective attachments to an MS Outlook. It can maintain the all email properties of DBX file into PST after the conversion of files too. The email structure of file contains To, Cc, Bcc, From, sender, receiver, etc. all will remains same. It provides an accurate 100% result of conversion of DBX files into a PST. This application allows user to preview the valuable email data items and users are able to verify the content of mails.It is a safe and a reliable solution for users to convert their DBX files and archive them into PST.
For Free demo version, you can visit :- DBX to PST Converter
Feb 27, 2017 | Express Computers & Internet
Dll missing
This problem occurs when the Previous version isn't uninstalled properly. The thing is that when a software is uninstalled some files often remain in the system. These files are ofter referred to as "Leftovers".
To resolve this issue Uninstall your software (i.e. Previous version of MS Office) using a special Uninstaller software. You can find one if you google these words "uninstaller".
Alternatively you may also find a complete guide on how to fix this problem at this link
Office 365 error The program can start because c2r32 dll is missing...
Hope this helps.
Mar 19, 2014 | Microsoft Outlook 2013 - Download - 1 PC
I cannot start my microsoft office outlook MAPI32.DLL is corrupt
This Common Mapi32.dll Errors occurs because of a corrupt or damaged windows registry. In this case you can resolve them by using a registry scanner which is updated with all the most recent information.
Apr 19, 2011 | Microsoft Computers & Internet
I had Microsoft 2003. Removed it and tried to install Office 2010. Now I have neither. My PC tells me that MAP132.DLL is corrupt and I must reinstall Microsoft 2003. But the installer won't work. It says...
Try running a search for the file mentioned (MAP132.DLL) and delete it manually, then try the reinstall again. To search for the file, click start and type the file name. For Windows XP and below click start - search and then enter the file name.
It may also help to uninstall all versions of Office, restart your PC and then try to reinstall. Sometimes certain files aren't removed during the uninstall but during the restart.
Best of luck!
Mar 07, 2011 | Microsoft Office Professional Edition 2003...
I have Yahoo! Messenger version 11. The first time Y! M go good, perfect. But the 2th time apair the mesage: ?YahooMessenger.exe - Ordinal Not Found?. I download all the versions of Yahoo! Messenger and...
dear frnd,
"""The ordinal 17 could not be located in the dynamic link library...
Comment by scadasw (see profile) - August 30, 2005
Yahoo! Messenger with voice (7,0,0,426) was compiled with an older version of MAPI32.DLL library. If you use MAPI32.DLL ver. 1.0.2536.0 (very recent: 1999!) it works."""
Above was quoted from a website. Um, is that same version you have now?
This might also help, but first, make note of exactly where your good, working mapi32.dll file is located, and make a copy of it to have for a quick replacement...in case fixmapi.exe puts a not-compatible version back but I dont think it should....
run this file located in c:\windows\system32\fixmapi.exe
You do want to sign out of and be sure ypager is not running before trying fixmapi.
Here is the Microsoft info on what fixmapi.exe does: http://support.microsoft.com/?kbid=228457
Note what it says about if you are using Microsoft Outlook (not same as Outlook Express)
Dec 26, 2010 | Computers & Internet
How to create and edit a notes in ms outlook 2003?
The fastest way to create a Note, regardless of where you are in Outlook, is by pressing CTRL+SHIFT+N. To access the notes folder (create/delete) look on the bottom left corner of a default outlook windows. you will see an icon like a yellow paper sheet with lift corner, click there.
Hope this helped.
Oct 13, 2010 | Microsoft Office Outlook 2003 for PC
Not able to access MS office
http://support.microsoft.com/kb/933347
Here is what you need. Just click the Link Above. Please Rate My Response! Thanks!
PREM
Feb 28, 2009 | Microsoft Office Professional 2007 Full...
Mapi32.dll file ismissing or wrong verion when italling office (outlook) on windowsXP pro
i read somewhere:Try renaming the MSMAPI32.DLL to MSMAPI32.XXX. Then try starting Outlook.
> File is at \Program Files\Common Files\System\MSMAPI\1033 for english
> systems
please let me know if it helped..
Oct 31, 2008 | ZT Group ZT Reliant 823XI38 Desktop PC
Cannot hoysync with outlook 2003
After installing, reinstalling, deleting, hard resets, hitting head against wall... I tried installing the Pocket Mirror conduit as a last ditch effort. An error message popped up saying it could not find the mapi32.dll file. I looked at another PC, located that file in the windows32 directory, copied it to my PC, and I was able to hotsync with Outlook. To test this, I uninstalled the Pocket Mirror and Palm desktop SW, then deleted the mapi32.dll. Installed the Palm 4.1.4 sw, outlook 101 update, plus the conduit update, had same error messages. Added the mapi32.dll to the windows32 directory - was able to successfully sync with Outlook!
Sep 11, 2005 | Palm Tungsten E Handheld
Microsoft Office Outlook 2003 for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
