Question about B&K Plumbing
How many mm to 1 foot - B&K Plumbing
  • 382 Answers
Dear sir
please note this in 1 feet=304.8 millimeter
hope answer the question
thank you
please vote
Posted on Oct 07, 2010
How do i create a rolled hem using my Platinum 750?? Do i need a special presser foot?
by rolled hem I imagine that you are trying to put something like rope in the hem to make a round edge
You can buy a 1/2 foot that allows the needle to get close to what ever is making the roll
see your local sewing machine shop
Jul 07, 2016 | Platinum Sewing Machines
The presser foot lever is loose and will not bring the presser foot up or down
First of all, I would recommend that you purchase a service manual. It is inexpensive, and I saw several for sale on eBay. For your purposes, it is helpful when trying to locate the particular fastener that governs the presser foot, and there's a drawing of it there.
It appears that that fastener--it's a 2.5 mm Allen--has worked itself loose. Your presser foot when raised should be 6.3 mm (5 dimes) above the needle plate. That's important to know, because if you're going to tighten the fastener, chances are the foot is no longer where it should be, and you should set it to the proper height before you tighten the fastener. Furthermore, your machine detects material thickness, but that feature is disabled if your presser foot is not correctly adjusted.
If you open the cover over the thread path and look closely, the particular Allen fastener you want is located behind and in back of the very long spring, about 1/2 way up. You can further identify it by looking at the shaft that holds the presser foot. It takes patience to tighten it; it's a tight space to work in.
May 31, 2015 | Singer Quantum XL-6000 Computerized Sewing...
How do i ce eate a top stitch from the front side of a garments with the singer merritt 4530
I"m not sure what effect you're after; however, if you are interested in doing standard top stitching, you can do so with a regular foot. A top stitch is generally anywhere from 1/16" to 1/4". The biggest challenge is maintaining the same distance from the edge throughout. Once you decide on how far from the edge you want to go, you can use a magnet on the needle plate or put a length of masking tape to mark the edge, or you can use a quilting foot if you want it to be 1/4". One secret is that a standard foot is already 1/4" from the needle to the edge. Another secret is to look at the fabric and edge, not the needle.
You would also generally make your stitch a little longer than the standard 2 mm--around 2.5 mm to 3 mm. You can use standard thread, or there is top stitch thread available. Until you get the hang of it, you might want to use thread that closely matches the color of the fabric.
Jan 08, 2015 | Singer Sewing Machines
Why does the needle hit presser foot?
Did you change the stitch selection, or have it on a stitch that is too wide for the foot that is attached?
Aug 02, 2014 | Husqvarna Viking Emerald 116 Sewing...
110MM os how many inches 300M are now many feet?
1 inch = 2.54 cm = 25.4 mm
1 foot = 12 inches = 30.48 cm
110 mm / 25.4 mm = 4.33 inches
300 m * 100 cm/m = 30000 cm / 30.48 cm/foot = 984.25 feet
Jul 18, 2011 | Office Equipment & Supplies
I have a 1981 yamaha XS400 special and i need to know how tight I torque the crank case halves.
Tighten the 8mm threaded bolts with the 12' or 13mm head bolts, or nuts, between 12 and 16 foot pounds, and the 6 mm bolts with the 10 mm head 6 to 8 foot pounds
Apr 14, 2011 | Yamaha XS 400 Special Motorcycles
I need a new "A"
Have you tried sewingpartsonline.com? Also, I am not sure what you mean by the 1/4" . Also, my first Viking machine was a cam model and all the presser feet that I had for that machine will work on the Fressia 425. However, the 425 will go 6 mm width and the old cam machine was considerably less. So I can't use the full 6 mm width with the old feet. If you can't find the foot on sewingpartsonline.com any Viking dealer should be able to get the foot for you.
Mar 19, 2011 | Husqvarna Freesia 425
93 accord timing belt installation
  • Car jack
  • Jack stands
  • Torque wrench
  • Chain wrench
  • 3/8 inch drive ratchet
  • 1/2 inch drive ratchet
  • 10 mm wrench
  • 12 mm wrench
  • 10 mm socket (3/8 inch)
  • 14 mm socket (3/8 inch)
  • 17 mm socket (1/2 inch)
  • 19 mm socket (1/2 inch)
  • Timing belt
  • Balancer belt
  • Bottle of Liquid Paper
  • Disconnect the negative battery terminal. Using a ½-inch-drive ratchet and the 19 mm socket, turn the center bolt on the crankshaft so that number-one cylinder piston is at top dead center (TDC). You will know you ware at TDC when the mark on the crank is in alignment with the arrow on the timing cover.
  • Disconnect the cruise control connector and remove the cruise control actuator. Loosen the upper mounting bolt with the 14 mm socket. Use a 12 mm socket to loosen the lower nut then use a 10 mm socket to loosen the adjuster from the power steering pump and remove the belt.
  • Loosen the upper air conditioner mounting bolt using the 14 mm socket. Use the 12 mm socket to loosen the lower nut and adjusting bolt on the alternator and remove the alternator/AC belt. Remove the valve cover using a 10 mm socket.
  • Place the jack behind the left front wheel where the arrow is located indicating the jack location, and raise the vehicle. Put the jack stand under the subframe behind the jack, then lower the jack. Remove the left front wheel for easy access to the crank pulley. Using a block of wood atop the jack, place the jack under the oil pan and lift with slight pressure to hold the engine in place. Remove the side engine mount using a 17 mm deep socket.
  • Take off the dipstick, pipe tube and upper timing cover using a 10 mm socket.
    Then remove the timing belt adjuster rubber seal without loosening the adjuster nut. Take off the crankshaft pulley bolt. Use the chain wrench to hold the the crankshaft pulley while turning the crankshaft pulley bolt with a 19 mm socket. Use the 10 mm wrench and 10 mm socket to remove the bolts on the lower cover. Remove the lower cover and mark the location of the cam, crank and balancer shaft with Liquid Paper. Remove the balancer shaft belt and timing belt. Install the timing belt and the balancer shaft belt in the reverse order of removing them. During Installation of the crank pulley, coat the threads of the crank pulley bolt with engine oil and tighten it to 159 foot-pounds. Finally, adjust the tension of the power steering and alternator belts as well.
    Feb 03, 2011 | 1993 Honda Accord
    What is the torque on a 1994 ford taurus thermostat?
    I believe those are only 6 MM bolts, I wouldn't go more than 75-80 inch pounds. If they are 8 MM bolts you can tighten them to 15-18 foot pounds. Now, 6 and 8 MM is the diameter of the bolt NOT the head size. To convert inch pounds to foot pounds multiply or divide by 12. For example 12ft.lbs. = 144in.lbs. 12X12=144.
    Feb 22, 2010 | 1994 Ford Taurus
    Plumbing Logo
    57 people viewed this question
    Top B&K Plumbing Experts
    Tom Chichester
    Bill Boyd
    Daryl Gleaton
    Are you a B&K Plumbing Expert? Answer questions, earn points and help others
