I have 4 Airtech Ceiling Fans with the RL117 Receiver and Transmitter. Two of the RL117 Receivers do not want to switch the lights on and off anymore but I can still change the fan speeds and nobody can fix the receivers for me in South Africa because they all say that they can't get any components for the receivers. Who can fix it for me or where can I get new receivers from?
  • Tony McClure Aug 13, 2012
    Hi, i have the same Air Tech fan and would like to know if you can tell me how to change the frequency on the fan.
SOURCE: Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Posted on Nov 14, 2008
bobotfel
  • 236 Answers
SOURCE: Remote operation of ceiling fan NOT working.
Try to check the remote control by using camera or cell camera, just use it as your eyes to see if the remote control emits signal. Just point your remote control to the camera and "on" then check if the remote control emits light, if no emitted lights means defective remote but if emit lights then the receiver is defective . Try also to locate if there are any reset or rst button on the remote control and press it then test.
Posted on Jan 10, 2009
  • 37 Answers
SOURCE: Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Posted on Jan 24, 2009
  • 13 Answers
SOURCE: Broken ceiling fan switch
home depot, Ace, true value cary rhem, probably better quality, doesnt sound like the one aloha uses are very rugged
Posted on Jan 27, 2009
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
My have a hunter ceiling fan with remote control.it comes on with the wall switch ,but the lights and remote control won't work .can someone please explain why?
Try changing the dip codes in the receiver & transmitter. I wouldn't advise putting in the same code for both fans. Also, you might need new receivers.
Feb 21, 2016 | Hunter Dryers
Can a the transmitter and receiver be replaced by wall control for a Hunter fan model 28425?
The part # you need is 85662-01-000. Maybe you can find it somewhere in cyberspace.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Our Minka Aire ceiling fan turns off all by itself (both the fan and light)
You either need a new receiver or you need to change the dip switches in the receiver & transmitter.
Aug 27, 2013 | Minka Aire Ceiling Fan
I have a Hunter ceiling fan with a remote control model number 85095. The remote will turn the fan on and off and change the speeds but it will not turn the light on or off anymore. Any help?
Make sure the wires to the light kit are connected to the light & light wire connected in ceiling.If that's not your problem then you probably need a new receiver. Call 1-888-830-1326 and have your FAN model handy.Should be a five digit number beginning with a 2.
Jan 14, 2013 | Hunter Ceiling Fan Remote Transmitter...
Remote control will not turn on/off fan or light. Has good battery. Where is the transmitter located on the ceiling fan?
The transmitter is the remote. The receiver is located inside the fan mounting bracket next to the ceiling. If you replace it make sure to set the dip settings on the new receiver exactly as they are on the old one. Wire the new receiver exactly as the old one is wired if it was working before.
Nov 07, 2009 | Hunter 52" Ceiling Fan With Light And...
Hampton bay ceiling fan (7030T) remote does not work.
This symptom is usually caused by either a bad receiver or bad transmitter. Install a new remote system (receiver & transmitter).
Apr 20, 2009 | Hampton Bay 52 In. White Redington...
Installation
I assume that you're talking about a remote-controlled ceiling fan.
There are two parts to a remote-control setup -- the transmitter (the switch which you use to operate the fan and/or light), and the receiver (which receives the signals sent by the transmitter, and directly controls the fan and/or light).
The receiver -- which should look like a plastic rectangle, usually white, grey, or orange-brown in color -- can be identified by the fact that it has several colored wires coming out of it, and doesn't have any buttons. This is mounted in the ceiling fan itself. On nearly all setups, it goes inside the canopy (the decorative part of the ceiling fan, up by the ceiling, which hides the fan's electrical wires).
The transmitter may be either hand-held like a television remote control, or in-wall mounted like a light switch. If you have the hand-held variety, there is nothing to install in a wall box. The wall-box wires should be appropriately connected up, and a blank cover plate should be put on top of the gang box.
If, on the other hand, you have the in-wall variety of transmitter, then yes -- it gets mounted in the wall, in a gang box, like a normal light switch or outlet.
If you need any further clarification, please feel free to ask!
Jun 17, 2008 | Hampton Bay 24002 Ceiling Fan
Light and fan won't come on. Remote control is working light switch tested and light test came on for fan, but not for light when chain was pulled.
This sounds like one of the most common problems with Hampton Bay's remote-contolled fans...either the transmitter (remote control) or the receiver (mounted in the fan, typically inside the ceiling canopy) has gone haywire. A circuit has blown or something is short-circuited, and it has a mind of it's own. Some things work, others don't, and others only intermittently. The only fix is to replace the receiver and transmitter, which are relatively cheap and sold as a pair at your local Home Depot and Lowes.
Hope that helps! If you ave any other questions, feel free to ask!
Apr 26, 2008 | Hampton Bay 24002 Ceiling Fan
Heating & Cooling Logo
204 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
