Hello, I need to replace my furnace control board #HH84AA015. I found the replacement part fairly quickly. Also found a bad transformer,#HTO1BC115 (primary winding indicates 'open' with ohm meter, applied 120vac to primary and found no secondary voltage present ). What, in your estimation, could cause this transformer to burn out? Could this cause damage to the control board? Any help would be greatly appreciated. The connector/plug is also showing signs of damage, but I need help locating it.
  • 455 Answers
Hello,The transformer (breaks) if the secondary is shorted for any reason.Also a power surge to the house/building will kill it (lighting strike/car hitting telephone pole).It might cause damage to the board.It is cheaper to try a new transformer BUT add a inline 3 amp fuse in the secondary so that will be the last transformer you have to replace(just fuses)if the short is hard to find.Power up the old board & see if it works,unless there is obvious damage.The plug sometimes comes with a new board because there is a wiring change to install it(on some) replacement boards.
Posted on Oct 07, 2010
This is a propane furnace that continues to run even after being shut off and plenum cools. No chimmey just pvc pipe to exhaust outside. Does that help.
The fact that the plenum cools down suggests that the thermostat is satisfying its setpoint and correctly turning off the gas flow....but....if the blower is continuing to run after the plenum cools down, it indicates the blower relay on the control board is stuck in the closed position (if it is a newer style furnace) OR the "fan' portion of the 'fan-limit' control is stuck closed if it is an older furnace.
If it is a newer one with a circuit board, the board cannot be field serviced...it must be replaced. Some furnace nmanufacturers have a secondary board that controls the fan alone and is cheaper than the furnaces with the single 'control board' that performs all functions of the heating/blower sequence.
Unless you have a fair amount of understanding of electricity, you should at this point call a service company for service.
Sep 29, 2015 | Heating & Cooling
Carrier Model 310AAV036070ADJA Furnace with a Honeywell EMM 3 Zone Controller went out after storm with voltage spike. No power going into Zone Controller or from Furnace Control Board to Transformer. Got...
if it was a big spike then i am afraid that the board might be damaged. check to see if you have a voltage safety on the board if not then you may have to replace to pc board
Sep 04, 2013 | Heating & Cooling
Armstrong furnace won't stop running
Hello, sounds like the relay on the intergrated control board is sticking. This will require the board to be replaced.
May 07, 2012 | Heating & Cooling
My furnace will light but not run. What do I do?
Hello, if the burners are lighting but the blower motor does not start it could be bad control board, capacitor or motor. In order to eliminate first jump power from L1 to the low speed motor wire, if the motor starts up you will need a new control board, if not the motor will need to be replaced
Dec 30, 2011 | Heating & Cooling
Furnace blower motor does not turn on
Hello, this can be a problem withnthe control board, capacitor, or the motor itself is bad. Try jumping the L1 wire with the low voltage motor wire , if this gets the motor running the control board is bad. If the board apperas fine and you have power to the motor then try to spin the blower wheel by hand, if this starts the motor then the capacitor is bad and will need to be replaced. if none of the above work the motor will need to be replaced.
Nov 26, 2011 | Heating & Cooling
Goodman furnace fan runs all the time
Hello, this can be caused by a bad relay on the integrated control board or a short in the low voltage wiring. Easy way to check is unhook the green wire from the G terminal on the control board, if it stops there is a short in tje wiring, if it does not stop the control board must be replaced due to a bad relay.
Oct 28, 2011 | Goodman GMS90703BXA Heater
How doI replace the motherboard on a American Standard Freedom 80?
Hello, to replace the intergrated control board on your furnace you need to turn off main power to your furnace, then label the wires so you will know where they go on the new board. Then just take the old board to a hvac supply store and they will give you a replacement and just connect the wires to it and turn on Furnace.
Mar 02, 2011 | Heating & Cooling
Furnace wont run ...thermostat battery went dead i replaced the batteries and still furnace wont run...We recently had a power outage for approximately 12 hours. This furnace is in our garage. we had...
Hello, The first thing you need to check with a multimeter is if you are getting 24 volts between the R AND C terminal on the intergrated control board. If not than the transformer is blown and needs to replaced or the fuse on the control board has blown and will need to be replaced. When check for 24 volts at the R and C terminal make sure the door switch is pushed in, u can just use electrical tape to temporaily hold the switch in. If you are getting 24 volts at R and C and notthing continues to run than the intergrated control board is most likely the cause and must be replaced.
Feb 04, 2011 | Goodman GMS90703BXA Heater
Rg(bu)h-07eauer have replaced the control board will not heat
read wiring and make sure flame sensor is clean and make sure you have good ground
Oct 16, 2009 | Heating & Cooling
Ignitor last a day then goes bad again going on 4th try help .
You are getting improper voltage to the ignitor. Check all grounds both in the furnace as well as at every connection heading back to the circuit breaker panel. If you find none, you will need to replace the circuit board.
Dec 08, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
