Question about Hitachi 50V720 Television
My input button on my Hitachi 50V720 will not select. All other buttons on the tv and remote work. I can scroll through the choices, but the select button will not select anything.
SOURCE: hitachi 50v720 tv
its a 1500.00 dollar light engine, the blue lcd light chip on the board is going bad.
Mike
Posted on Aug 04, 2008
  • 188 Answers
SOURCE: Hitachi TV volume won't work
Is the set in hotel mode?
Posted on Jul 24, 2009
  • 476 Answers
SOURCE: cannot change input source for tv
i would try the abvious first, unplugg the tv from the ac outlet and wait for a few seconds then try turning tv on see if the problem is solved, if not it might be that the key board panel needs replacing.
Posted on Aug 02, 2009
satavlad
  • 405 Answers
SOURCE: no input selection availiable on sharp aquos lcd tv
You have to come back to EZ SETUP and complete the setup procedure. Press MENU>SETUP>EZ SETUP.
Posted on Dec 29, 2009
  • 4 Answers
SOURCE: I have no power to my Hitachi TV. It is plugged
try turning off main switch and unplug set then replug in wait 30 sec turn on main power and repeat then try if it works great if not power supply bad. i also suggest a ups universal power supply newer tvs sensitive to surges and brownouts also never turn tv off n on in short period of time will cause surge that trips protection circuit
Posted on Jan 24, 2010
How can I get the TV to set to hdmi?
If you have a Hitachi remote HL02121, that means your TV model number is either 32PD7800 or 42PD7800.
According to the Owner's Manual the HDMI connector is activated by going to AV6.
While in the TV mode on the remote, press the '' button with the AV6 above it. That will tell the TV to use the HDMI input.
IF you don't have access to the TV remote, there are INPUT SELECTION buttons on the TV near the Lower Left hand Corner of the cabinet. Press the INPUT SELECTION button until AV6 is displayed on the screen (HDMI Input)
Feb 19, 2016 | Hitachi CLE-960 Remote Control HL02121
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): http://www.crutchfield.com/S-QWOJIeQP36Y... kg7or ยท 4 years ago
All the info on the television including manuals and inputs can be found here,
ftp://ftp.panasonic.com/television/howto/combo_connections_howto.html
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
Hitachi Deskstar 123.5GB drive running through an external Dock via USB. When switched on icon mounts on desktop but will not Open?
Make sure you haven't selected the wrong input using the input or source button on your remote control. You may have to cycle through several choice until you get to TV or Tuner or something similar. Cycle slowly, some TV's take a few seconds to render the picture one you choose a different input source.
Jan 07, 2015 | Hitachi Computers & Internet
Changing inputs on hitachi tv 46w500 with out a remote
The Hitachi 46W500 has an Input button on the front of the TV. (This is the second button from the right. The right-most button is the Menu Button.) You should be able to press this repeatedly to switch between inputs.
If the Front Panel Lock is engaged, you need a remote to unlock this. (Only the Power button works when the FPL is engaged.) A universal remote which has a code that matches that needed to get the Menu button to work will do the job.
I hope this helps.
Mar 22, 2013 | Hitachi 46W500 46 in. TV/DVD Combo
How to switch tv over to play games on wii
press menu button and look for source or input and manually do it onscreen, different buttons scroll through choices, enter button selects choices
Aug 20, 2012 | Toshiba 30HF66 30" TV
Inputs will not change with remote with my Harmont reomte
Hello
It will be difficult to match any other universal remote with this model Hitachi set. You have to get the original remote control to select all the functions with this TV. If your original remote control doesn't work at all, just buy a new one. You can get it from the authorised service center for Hitachi at your town. OK.
Nov 04, 2011 | Hitachi 55HDS69 55 in. Plasma Television
Change from TV mode to AV mode for a Hitachi C28W4110SN
There should be buttons somewhere on the TV itself to switch input modes. Look around where the power button is located and see if there is a menu button you can access. Then use channel up/down and volume up/down to scroll thru modes to find input
Hope this helps
TankMurdock
Apr 27, 2009 | Hitachi 61SDX01B 61" Rear Projection...
42HDS69-INPUTS
couple of ideas ... on the TV look for the button named input you can change it to the one you cave connected to there .. I am looking up the remote press the TV button then the menu button to move through the on screen input control
Sep 19, 2008 | Hitachi 42HDS69 42 in. Plasma Television
50" Hitachi Ultravision 50V720 with pink hue screen
Always research your model at www.HitachiServiceUSA.com.
Many entries for your model.....................T.
Nov 28, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V720 Television Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
